pacmanfan
v6.28 unstable after importing certificate
Sat May 16, 2015 8:27 am
I am using the following guides to set up OVPN server, using a certificate from CACert:
http://wiki.mikrotik.com/wiki/OpenVPN_C ... ep_by_Step
http://wiki.mikrotik.com/wiki/OpenVPN#C ... CAcert.org
Immediately after importing the certificate-response.pem file (the cert from CACert), free memory begins dropping steadily for about 15 seconds, before it suddenly nosedives to around 4mb, CPU usage hits 100%, and the router drops all connections for a little bit. Once I can get back into winbox, the free memory countdown has already begun again. This cycle repeats about every 30 seconds, indefinitely. When I delete the imported cert, the memory usage stabilizes, but the CPU stays at 100% until I reboot the router.
This is repeatable in my environment, I cannot get it to import the certificate without immediately becoming unstable.
This is on an RB2011iL-RM.
pukkita
Trainer
Trainer
Re: v6.28 unstable after importing certificate
Sat May 16, 2015 3:29 pm
could you post /system routerboard print?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
pacmanfan
Mon May 18, 2015 4:42 am
[user@MikroTik] > /system routerboard print
routerboard: yes
model: 2011iL
serial-number: 5BED040DFCBE
current-firmware: 3.19
upgrade-firmware: 3.22
pukkita
Trainer
Trainer
Mon May 18, 2015 12:32 pm
Can you import again that cert but this time with an eye on /tools profile looking for the most CPU consuming process once you click on OK for the import?
pacmanfan
Thu May 21, 2015 2:57 pm
Well, the behavior changed a bit... Now when I import the cert, the memory loss is happening very slowly, with free memory dropping from 45mb to 32-35mb in 15-18 minutes, at which point a runaway memory/cpu use crunch occurs, triggering a reboot--every 15-18 minutes.
The cpu profile category that shows high usage during the runaway is "unclassified".
pukkita
Trainer
Trainer
Thu May 21, 2015 3:44 pm
Have you tested if it happens also with older ROS versions? (downgrade)
pacmanfan
Fri May 22, 2015 10:14 am
No... This RB2011 shipped with a relatively recent v6 version, and I don't think I can downgrade it to v5. Would it be worth downgrading within the v6 branch?
pukkita
Trainer
Trainer
Fri May 22, 2015 11:18 am
Yes, I meant 6.27 no need for 5x...
mrz
Fri May 22, 2015 1:05 pm
Does certificates use CRL?
miffe
Fri May 29, 2015 12:31 am
I upgraded from 6.27 straight to 6.29 and now have the same problem. It runs out of memory in under 30 seconds.
Deleteing all certificates fixes the problem.
I use GoDaddy certs and they use CRL.
miffe
Fri May 29, 2015 12:40 am
The CRL url for my certificate is: http://crl.godaddy.com/gdig2s1-87.crl
mrz
Fri May 29, 2015 12:33 pm
It is 6.5MB large file, internally by SSL library it will use ~65MB of RAM. Make sure your router has enough free memory, for routers with less memory use certificates without CRL.
endurofever
Sat May 30, 2015 4:40 am
Can we disable the CRL functionality so that we can still import these CA's?
I ran into this one with CA Cert today and it had me stumped for hours.
mrz
Mon Jun 01, 2015 10:44 am
Please contact support.
Users browsing this forum: Ahrefs [Bot], tamagochi and 23 guests
