MUM Europe 2020
williamdf
Accidentally blocked tcp connections
Mon Nov 23, 2015 4:34 pm
I blocked tcp connections accidentally and I can not log in RB2011UiAS-RM mikrotik.
Is there any way to disable firewall rules without having to reset factory defaults?
Thanks.
chechito
Re: Accidentally blocked tcp connections
Mon Nov 23, 2015 4:53 pm
try acces by mac address using winbox, just click on mac address not ip address
williamdf
Mon Nov 23, 2015 5:20 pm
I tried this procedure and returns the error 20561.
I checked on google several procedures to correct this error, but all have failed.
Any suggestion?
williamdf
Mon Nov 23, 2015 6:46 pm
Sorry,
the information is timed out, referring to the connection via port 20561.
cberni
Tue Nov 24, 2015 6:03 pm
I had the same problem adding a firewall rule. All TCP ports seems to be blocked. Is there a way to login again without factory reset? by USB or a way disabling firewall rules?
texxok
Wed Sep 14, 2016 3:44 pm
Hello guys
We run into the same problem. But solved it.
The connection using MAC address from win-box didn't work for us.
1# But you can use mac-telnet from another RouterOS http://wiki.mikrotik.com/wiki/MAC_access, we luckily had another Mikrotik in our network.
So connect to it:
/tool mac-scan
/tool mac-telnet 00:02:6F:06:59:42
-- login --
/ip firewall filter print
/ip firewall filter set 1(number of rule) disabled=yes
Disable the firewall rule.
2# It should be possible to connect using serial port, if you have it on your Mikrotik device http://wiki.mikrotik.com/wiki/Manual:Fi ... rial_Cable
Regards
Users browsing this forum: No registered users and 11 guests
