Aminzakeri
user manager for hap lite
Tue Jan 26, 2016 5:46 pm
i have a routerboard ( hap lite RB941-2nD ) and i want to install user man. on it.
pls...Help Me..
freemannnn
Long time Member
Long time Member
Re: user manager for hap lite
Fri Feb 05, 2016 12:10 pm
not possible. not enough memory and cpu power for user manager.
hap lite is intended for home use.
amitkw
Sat Jul 01, 2017 8:44 am
Hello Aminzakeri,
The hap lite routerboard series does not support userman. As an alternative I suggest that you use The Userman application. This application can generate user, time limitation and print a simple hotspot voucher. More information please visit this address http://theuserman.blogspot.co.id/p/tentang.html
omidh
Sat Jul 01, 2017 8:59 am
you can use external radius server or online user manager.
try using http://www.ebss.cloud
freemannnn
Long time Member
Long time Member
Sat Jul 01, 2017 9:56 am
i dont see the point paying fees per month to on line radious services than buying a better mikrotik device like rb951 (level 4) or rb2011 (level 5) for usermanager.
omidh
Sat Jul 01, 2017 10:11 am
Mikrotik Userman is simple and does not have many features.
by using cloud radius in addition to initial facilities you get many features like SMS based authentication, polling system, configuring and design hotspot login page and ....
Nanafitripermana
Sun Apr 08, 2018 9:11 pm
Tray the user manager dekstop version, you can follow this link https://theuserman.blogspot.co.id/2017/ ... 6121865511
This aplikasion can run, must at the service avi on router is enable. Thare are windows and linux version
christiansasig
Wed Jun 06, 2018 5:21 pm
Hello, I found this incredible app for android is called MikroTicket https://fhx47.app.goo.gl/mikroticket generates tickets or vouchers for access by hotspot mikrotik and you can configure access times, bandwidth, time runs and makes automatic removal of the vouchers, I use it in my business. https://youtu.be/DZqg4BIMEUw Regards
marlonz2
Tue Jul 09, 2019 4:53 am
Sir I tried to do that. But I currently getting a "This password is incorrect" error. How do we fix this?
Users browsing this forum: No registered users and 3 guests
