cedie
um 6.37.1 timezone issue
Wed Nov 09, 2016 4:42 pm
hello,
when i add validity to profiles that starts at first logon i got a different timestamp in startime field it is delayed by 8 hours. my timezone is +8:00 and set correctly in system clock and activated sntp client. um router timezone is parent while customer is +8:00, i did change router and customer to +8:00 to no avail.
thanks
igpetkov
Re: um 6.37.1 timezone issue
Thu Nov 10, 2016 8:58 am
Same problem, Can someone help us?
cedie
Thu Nov 10, 2016 2:40 pm
back up file naming is also affected, dont know what else to do as i've tried every possible cause
PaulsMT
Fri Nov 11, 2016 11:25 am
Thank you for reporting, seems like the backup save time needs a fix. But I did not saw any problem with the session from time. Can you give more examples ?
Sessions/logs/reports show correct from time, if the customer time zone is set (6.37.1/6.38rcX)
cedie
Fri Nov 11, 2016 3:26 pm
hi paul this is on +8:00 timezone, start time it is clearly delayed by 8 hours from the real start time
cedie
Wed Nov 23, 2016 3:52 am
even after upgrading to 6.37.2 start time is still off by 8 hours
vipe
Tue May 09, 2017 7:13 pm
6.37.5 timezone bug +1
Users browsing this forum: No registered users and 13 guests
