clarksheng
User Manager Till Time and Total Time Left are showing UNKNOWN.
Fri Oct 13, 2017 1:11 pm
I have been battling against this problem days and nights.
As the screenshots suggest,
I have set the time zone of all above fields exactly the same,
and then what I found is,
I have to emphasize the till time and total time left are showing because I re-built the log and/or clear the log.
Otherwise, all will be showing only Unknown.
I believe this is a bug obviously, so hoping mikrotik can get this fix a.s.a.p.
Ghalebi
Re: User Manager Till Time and Total Time Left are showing UNKNOWN.
Wed Mar 14, 2018 5:06 pm
Has this been solved? I have the same issue!
Users browsing this forum: No registered users and 7 guests
