pkpk
Hotspot + UserManager
Thu Jan 03, 2019 4:25 pm
Hi, I have some problem with radius (User Manager)
I'm config CCR1009-8G-1S-1S+ like a Hotspot + UserManager + some filtr rules and custom logs ( I'm using theDude)
If connecting is 100 or more user to hostpot, Radius don't responsing (in log) and when client trying login to HotSpot. I can login UserMan normally - but if I trying rebuild datebase nothing happen and I got info "datebase busy". After reboot everything is ok, but not to long. However, users outside the usermanager can log in always without any problems.
I am found some info, most people recommend move radius to other RouterBoard or PC, but CCR1009-8G-1S-1S+ may be to slow for this simple config ?
I have useless RGb433AH and 951Ui-2HnD - what do think, can I use this for only Radius Server, or you recommend somenthing better ? Or maybe I should use external memory like sdcard ?
Users browsing this forum: No registered users and 8 guests
