Aktivbox
USB Stick Problem
Mon Mar 25, 2019 9:33 am
i`ve a Problem with my Hotspot running on Hex2 Lite 6.43.2
Usermanager stopped cause of Memory full
8GB USB Stick ext3 formatted should solve my problem.
Everything worked fine, but after 3 Weeks Hotspot went down.
The USB Stick was EMPTY. Trying formatting ext3 again failed. Fat32 was possible.
OK, I bought a new Stick
But, same Problem.
After a couple of Days the Stick was empty.
Any Idea?
vecernik87
Forum Veteran
Forum Veteran
Re: USB Stick Problem
Mon Mar 25, 2019 9:55 am
What part of "memory" got full?
Was it RAM? Storage (flash)?
Just plugging USB stick into router won't solve the issue - how is the device supposed to know that it should save data on it?
Aktivbox
Sat Apr 20, 2019 2:17 pm
the Hex2 Lite has only 16 MB RAM (In former times i use 750GL with 64MB)
Read here: viewtopic.php?f=3&t=101670
So i stick 8GB USB ext3 formatted in.
I move userman DB etc. onto the stick and changed Path. It works fine!!!
BUT after a few days Hotspot stopped. No Database on the Stick.
Stick was totaly empty and i wasnt able to format it ext3 again (failure massage) fat32 works.
I bought an other stick - same result. Works for a couple of days - then- Stick empty.
Wrong Stick???? I bought different ( No no name)
Any Idea??
Users browsing this forum: No registered users and 13 guests
