Spring
Usermanager being reset on every reboot
Mon Mar 02, 2020 8:00 pm
Hi, my RB750r2 always lost usermanager's configuration and any user records on every reboot... is anyone have that problem too and have fix it?
I already update the packages to the latest version (6.46.4) and have upgrade the firmware
                  version: 6.46.4 (stable)
               build-time: Feb/21/2020 11:26:37
         factory-software: 6.28
              free-memory: 33.0MiB
             total-memory: 64.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 850MHz
                 cpu-load: 8%
           free-hdd-space: 1464.0KiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 267
         write-sect-total: 214362
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: hEX lite
                 platform: MikroTik
       routerboard: yes
             model: RouterBOARD 750 r2
     serial-number: 67D207041CF1
     firmware-type: qca9531L
  factory-firmware: 3.36
  current-firmware: 6.46.4
  upgrade-firmware: 6.46.4
Abduljbbar
Re: Usermanager being reset on every reboot
Sun Mar 22, 2020 1:16 am
Hi this is my 1St reply here
so do you notice this issue before the upgrading or after
if it is started after the upgrade try to:
1.rebuild UM data base if not working.
2. downgrade your version to the old one and check it it is work
3. if both not working try to re setup the user-manager
i am beginner in microtik so maybe the other members have better answer to your issue
Oh, Allah save my peoples and all in the earth
Users browsing this forum: Baidu [Spider] and 11 guests
