cubacan
RB112 3.2 upgrade problem
Sat Feb 02, 2008 4:14 pm
I have upgrades my rb112 3.1 to 3.2 using webpage but now I can't recognized on the network.
I have used file mipsle it is correct for RB112 ?Is there remote recovery procedure ?
The board is far to 70 km !
cubacan
Re: RB112 3.2 upgrade problem
Sun Feb 03, 2008 6:53 pm
What is better version RB112/RB523 for a stable wds point to point ?
sergejs
Mon Feb 04, 2008 6:48 pm
cubacan,
yes mipsle is correct packages for RB112.
Do you have wireless connectivity or Ethernet to this router ?
Probably it is possible to access neighbor router and use 'ip neighbor' to access this router with MAC-Telnet.
If router is not displayed in neighbor list. You will need to get local access to router. It is better to take null modem cable and check the console output.
v3 should be good enough to establish WDS link.
Users browsing this forum: No registered users and 9 guests
