kamal
Mikrotik New User Manager Not working in Profile Timing ?
Mon Dec 21, 2009 5:46 pm
I Add Timing in Profile like
8 am to 9 pm 128k
and
9 pm to 8 am 512k
But after 9pm my user not connected and get error of verifying user name and password so i double check and get that in profile first one(time limit form 8 am to 9 pm) is activated and working but second timing not working so can any one tell me how to do that.
sergejs
Re: Mikrotik New User Manager Not working in Profile Timing ?
Mon Dec 28, 2009 12:10 pm
You should CoA for the profiles, which have different limitation in different time.
There should be 'radius-incoming' enabled in HotSpot, and for User Manager menu you have to configure the particular router to support CoA.
kamal
Sat Jan 02, 2010 4:52 am
but i m using PPP so can you tell me how to do that
sergejs
Thu Jan 07, 2010 11:54 am
PPP does not support CoA unfortunately.
dunga
Sun May 15, 2011 1:19 pm
Can U explain what you mean on the above cus i have tried them, yet it cannot work. Can u give detailed or graphic picture of how to set this different timing for user in user manager test package.
Here is sample done already
Users browsing this forum: No registered users and 3 guests
