MUM Europe 2020
mynetcsp
how to install new usermanager
Mon Mar 01, 2010 2:34 pm
how to install new userman i am using router os 4.6
JP_Wireless
Re: how to install new usermanager
Sat Mar 06, 2010 6:42 pm
Download the file from mikrotik.com/download, transfer to the router using ftp (easier for me compared to the netinstall) and reboot the router and it will be automatically installed or upgraded.
JP Wireless:::
One Stop ICT, Alternative Power & Electronics Securities Solutions Provider!
Tel: +2348098798779, +2348055353151
http://www.jpwireless.net: Email: info[at]jpwireless.net
36, Diya Road, Gbagada, Lagos - Nigeria.
eneimi
Sun Mar 07, 2010 5:48 pm
UM4.6 test is not yet available. If you must use UM, downgrade to ROS4.5 and download and install UM4.5.
When UM4.6 is ready, download link will be posted here: http://forum.mikrotik.com/viewtopic.php ... 76&start=0
mynetcsp
Wed Mar 24, 2010 10:32 pm
i am install usermanager 4.6 but old usermanager data base errer colum 19 etc any solution thanks
andrescamino
Wed Mar 31, 2010 8:14 pm
you have to download the UM 4.6 test version, then go to the folder with all the packages, rename the UM test version with the actual name of the usual version, then delete the normal and paste the test version with the name of the normal UM and then you can work normally as you were working with the previous one.
That's how i did it and it worked fine
Andres
dormador
Wed Mar 31, 2010 9:40 pm
+1
i have the same problem .. the old data base !
Users browsing this forum: No registered users and 5 guests
