ruhanda
Customize Signup page was not working
Fri Sep 03, 2010 10:56 am
I found below guideline from Wiki but it was not working on my mikrotik version 4.9
I want to modify signup page and user page but no lucky.
I can access sign up page and display without any problem but NO "umfiles" directory listed after first time access it as wiki mention below.
any mikrotik expert or gurus can guide me how to modify signup page?
http://wiki.mikrotik.com/wiki/User_Mana ... ser_Signup
Customization steps
To customize signup pages, follow these steps:
Signup page must be accesses at least once, because template files are created on first request. Therefore open signup page in your browser. If you have opened signup page previously, skip this step
Log in to your router using FTP or SFTP and download "umfiles" directory containing all required files to your computer. If there is no "umfiles" directory, see previous step
Edit the files using text editor of your choice. Editors supporting HTML syntax highlighting could aid you. See: HTML Editors
xavierhoughton
Re: Customize Signup page was not working
Thu Sep 09, 2010 4:10 pm
same problem with 4.11
connect to router with winscp using admin login
no umfiles folder
open browser (firefox)
go to http://x.x.x.x/user?signup=xxxxx
refresh router directory
no umfiles folder
got to http://x.x.x.x/user/signup/xxxx
no umfiles folder
dainen
Mon Sep 13, 2010 11:27 pm
We are having exactly the same issue using ROS V4.11 , the pages have been used multiple times for testing the PayPal payment process, and it works exactly as it should.
Except the /umfiles they simply aren't visible with ftp, winbox or terminal.
Has anyone solved this one yet ?
nickb
Fri Sep 17, 2010 10:10 pm
According to Normis, it only works in the -test package http://forum.mikrotik.com/viewtopic.php ... on#p226398
Unfortunately I can't find it to download!
normis
Mon Sep 20, 2010 9:50 am
mahdi1358
Mon Dec 19, 2011 7:54 am
is it possible in 5.12 OS??
We are alone!!
Users browsing this forum: No registered users and 9 guests
