neandero
Managing User Session Idle Time Limit!
Thu Jan 13, 2011 5:33 pm
I have many users complain that they are unable to login - error: simultaneous session limit reached
what setting on idle time should i have to set on hotspot to match setting for idle on UM?
for some reason or another, when i set 15min on hotspot, they do get kicked off on HS but session keeps active in UM!
thanks
Note: shared users must stay 1 for any changes...
sergejs
Re: Managing User Session Idle Time Limit!
Fri Jan 14, 2011 11:12 am
Please, post your /log print, here when you get the particular error.
neandero
Fri Jan 14, 2011 4:31 pm
14:49:18 hotspot,info,debug username (10.10.40.243): trying to log in by http-chap
14:49:20 hotspot,info,debug username (10.10.40.243): login failed: simultaneous session limit reached
14:49:48 hotspot,info,debug username (10.10.40.243): trying to log in by http-chap
14:49:50 hotspot,info,debug username (10.10.40.243): login failed: simultaneous session limit reached
15:00:17 hotspot,info,debug username (10.10.40.243): trying to log in by http-chap
15:00:19 hotspot,info,debug username (10.10.40.243): login failed: simultaneous session limit reached
as you can see in red, after 10 of waiting, the session keeps the user active.
i would wish if there is any setting on HS or on UM that i can change that would synchronize idle time with each other.
thank you,
sergejs
Mon Jan 17, 2011 8:30 am
This error means, that one user with same username/password is already logged at User Manager.
What kind of idle are you talking about?
neandero
Mon Jan 17, 2011 12:36 pm
I believe I found the main cause, but not the solution :?
if, for any reason, the router reboots, such as power lost - everyone on that router will be removed, and because
the UM manager had not received accounting stop commands, remove commands, the sessions stays active on the UM
and the users will not be able to re-log in...
ok, this is the cause I know 100%
now, solutions?
is there a way for routers to send commands to UM at boot up to remove some user sessions so users can be able to
log in?
nice day,
sorry, I though it was about Idle remove time, but I guess I was wrong... :D
sergejs
Tue Jan 18, 2011 3:47 pm
/system reboot
/system shutdown
must send accouting stop commands for all users.
power lost is another case, any of the RADIUS server does not know anything about possible power loss within 25 seconds.
So in my opinion, it is very useful to get stable power for RADIUS server (router) to avoid any unmanaged power losses. Good UPS should be fine and router could be shutdown in case of power failure.
sumair88
Tue Feb 14, 2017 3:13 pm
can any one tell me how to fix this problem ???
ghanem2000
Mon Jun 19, 2017 4:47 am
is still there no any solution! :shock: please need help !!! :( :( :(
onci
Mon Apr 06, 2020 5:46 pm
We have the same problem. HS/routers loosing power will not sent any notification about power outage to the UM.
Mikrotik should implement any SW solution and not recommend to have UPS.... ...
Mikrotik should keep database about Active users and after power outage should insert them into Active again I believe.
Or script on Error Simultanious session reached check uptime of HS is less the Uptime off the session? = allow login as normal
Users browsing this forum: No registered users and 6 guests
