edris
User manager 5 profile starts issue!
Wed Apr 06, 2011 12:37 pm
how can i change "Starts: now" option in profile menu. my problem is when i add new user and assign it specified profile. user profile will be activated just after adding user Not after "Users first login".
elnagar_ali
Re: User manager 5 profile starts issue!
Wed Apr 06, 2011 9:53 pm
unfortunately . i suffer from the same problem like you . i want to restore the old configurations like "at first month"
edris
Fri Apr 08, 2011 12:44 am
any update....
adryfia
Fri Apr 08, 2011 2:41 pm
No update or fix from mikrotik team, so back to v5rc10 againt.
edris
Mon Apr 11, 2011 10:07 am
Same problem on user manager 5.1..!!
adjoneidi
Thu Apr 28, 2011 8:57 am
I have a problems same you by ver 5.2 in rb750g
soosp
Thu Apr 28, 2011 12:10 pm
Same issue on x86 board with User Manager 5.2. Additionally the status refresh (remaining time) of users isn't updated for the next login of the customer even if you reload the page in your browser.
siprox
Fri Apr 29, 2011 11:07 am
oh no no, why userman v.5.2 still same with older release, still can't setting voucher start counting from 'first login' then 'now'.
im try create user and generate the voucher, time left total will decrease if i click the title sorting time left total, decrease until 'unlimited', im very like v.5x we can print the voucher with small size, breaking the voucher to more than 3 voucher per page, its very cleaver, because will shrink the paper using.
please answer this question to make clear, we can't live without Mikrotik userman.. :?
adryfia
Sat Apr 30, 2011 3:40 pm
I not understand why mikrotik team not fix start issues at User manager v5.2, :?
siprox
Mon May 02, 2011 8:33 am
ayo rame2 komplen disini, biar Mikrotik v.52 bisa lagi profile nya. keren tuh. mana anak2 fmi. :D
adryfia
Mon May 02, 2011 6:38 pm
Mana bisa mereka ngarti base loe dul.......... :lol: :lol:
siprox
Tue May 03, 2011 12:28 am
hi adryfia, did you still use v.5rc10? working well?..
adryfia
Tue May 03, 2011 5:31 pm
It's working gan.
siprox
Tue May 03, 2011 11:25 pm
well, it seem i must go back to 5rc10 if next release 5.3 still facing the same problems :( bad news..thanks info nya gan.
beepee
Thu May 05, 2011 5:22 pm
I've found a way around this
Set the "start at" from console
[Admin@Mikrotik] > tool   user-manager profile set  23 price=200 starts-at=logon validity=1d name-for-users=Mono
I did it and it worked
siprox
Fri May 06, 2011 4:42 pm
how about voucher, as we know will generate random name user and password..??
beepee
Thu May 12, 2011 8:37 pm
Well, I guess you are talking about how to idenitfy newly generated batch users, if so, use a unique username prefix to identify the batch
normis
Fri May 13, 2011 10:18 am
profile start at first login has never worked before. the option was there but with no functionality. we removed this function because it was not functioning. there is no use to downgrade, the option will not work anyway.
we will try to make this function, and then we will return it to user manager.
currently there is NO such version where "first login" option works! there is NO need to downgrade.
siprox
Fri May 13, 2011 11:34 am
Am glad to hear that, profile start will return it to usermanager like on v.4.17. at least i hope when i create voucher the total time left not self decreased and the voucher validity will count from the first logon/start-at, or maybe we have another choice than that.
thanks for info.
beepee
Tue May 17, 2011 11:31 am
I dont subscribe to that
I have used this option several times on version 4x
And presently I am using it on version 5.2
All U have to do in version 5.2 is to create the profile in userman and then go to the console and change the "start-at" option for that profile to "logon" then create users with that profile. ( I bet U it works)
Normis, pls I want U to confirm that.
siprox
Tue May 17, 2011 12:07 pm
hello beepe, i knew it will work, but im not confortable with that, im usualy create much of voucher generate and then printing on papers, please think, if i generate hundred of voucher, how i can change from console, do you have idea? your example above show me you change just one user, its easy but crazy on alot of users generate voucher, now please tell me, this not happen on version 4.17 right?
im sure, i will soon use version 5.x if usermanager work normally like version 4.17.
beepee
Tue May 17, 2011 1:38 pm
Siprox,
Note the sequence of what I did
First, create profile in userman
Secondly, set the start-at time for the created profile from console. Once this is done, any user created with this profile will start at logon.
Thirdly, create batch users ( choosing the profile U just created) and print as U deisire, all the created users will start-at logon.
Pls note that the start-at option is a profile option and not users option and as such U dont need to set it for every user.
I also do the same here and I just created over 400 batch users that activate at logon.
alginne
Tue May 17, 2011 2:05 pm
hello sir,
how do you change the "starts now" in profile to starts on log-on?
siprox
Tue May 17, 2011 2:26 pm
owh, thanks for advice beepee, thanks for share. i think staff Mikrotik must say like you are but not, or maybe they don't know this issue. i don't understand.
i will try soon and post back here.. sek tak cobo disik yo. :D
siprox
Tue May 17, 2011 2:34 pm
hello sir,
you can try what Beepe said above, i also will try to.
beepee
Tue May 17, 2011 3:14 pm
alginne, follow siprox advice, it should work
Siprox, THANKX FOR THAT KARMA. :D
alginne
Tue May 17, 2011 6:08 pm
ok thanks it works, it wont change the word Starts now, but really works..
alginne
siprox
Wed May 18, 2011 1:29 am
note, three first row the user i created with adding command to "start-at=logon", three is showing start time "not set" but it working.
and then three after that i not set start-at on different profile and the total time left will decreased self even user not logon, because of start-at at default is "now", or in my perception is after we create the voucher the user start will start counting, in my test on a day remaining time left total will unlimited whereas user not logon.
available option on start-at is, now, month, and logon. maybe any one other have try this?
elnagar_ali
Sat May 21, 2011 10:50 pm
its work fine in my routerboard os 5 rc 10
plz return it back
siprox
Sun May 22, 2011 2:58 am
plz return it back
normis said they will try to make this issue will working on next release but i don't know on v.5.3 or not.
normis
Mon May 23, 2011 10:28 am
yes, we will try to fix it in v5.3
siprox
Wed May 25, 2011 2:52 am
nice to hear that, i will be patient enough for waiting till it released.
NetworkPro
Sun May 29, 2011 11:24 pm
Any update on this guys? Normis ?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Users browsing this forum: No registered users and 9 guests
