Fumi
New Usermanager v5
Wed Jun 29, 2011 8:23 pm
Hi all!
I need to configure usermanager and I have some questions.
There is manual for new usermanager?
I need to know how configure user--> wireless
Wireless->
Preshared key:
Enc key:
Enc algo:
What is the configuration in usermanager GUI and winbox?
Thanks..
Fumi
Re: New Usermanager v5
Thu Jun 30, 2011 11:18 am
Please mikrotik guys! I need some help! :?
normis
Thu Jun 30, 2011 11:19 am
let's start by moving your topic to the correct forum section
Fumi
Thu Jun 30, 2011 11:29 am
sorry...
There is any example or something to configure wireless section?
sergejs
Thu Jun 30, 2011 1:28 pm
http://wiki.mikrotik.com/wiki/User_Mana ... ss_Example
I recommend to start from the link above.
For
Preshared key: Set this key for WPA/WPA2 (the same as WPA Pre-Shared Key/WPA2 Pre-Shared Key in Winbox).
Enc key: leave it blank for WPA/WPA2.
Enc algo: select AES-CCM or TKIP (AES is more recommended);
Fumi
Thu Jun 30, 2011 2:12 pm
Thanks!! and sorry to put this message in wrong site..
Two last question..
Wireless clients should be Mikrotik? I try with laptop and log: got RADIUS accept for XX:XX:XX:XX:XX:XX on wlan1, but failed to validate encryption key.
UserManager support EAP authentication?
Thanks!
Fumi
Thu Jun 30, 2011 2:39 pm
I follow the steps in manual but if I don't active WEP or WPA in wireless security profiles, then the comunication is not encrypted.
If in security profiles leave Mode: none (encryption) then RADIUS users can connect via wireless!!
But if I set Mode: dinamyc keys then users cannot connect..
I need RADIUS wireless users connection ecnrypted.
Fumi
Fri Jul 01, 2011 2:14 pm
anyone have any idea about it?
sergejs
Fri Jul 01, 2011 4:26 pm
No.
Use mode=dynamic-keys
Configure WPA/WPA2 PSK on client laptop.
Fumi
Mon Jul 04, 2011 11:50 am
Ok... but what is the function of wireless parameter in usermanager v5? wireless key?
If I configure security profile with dynamic keys wpa psk then I put a unique key.. I don't understand what is the function of parameters (wireless encryption) in usermanager v5
Fumi
Wed Jul 06, 2011 11:23 am
Anybody know about this?
sergejs
Wed Jul 06, 2011 4:35 pm
For
Which key do you mean? Please post screenshot!
Fumi
Thu Jul 07, 2011 12:13 pm
This paramaeters
sergejs
Thu Jul 07, 2011 2:23 pm
Did you see my post above?
Fumi
Thu Jul 07, 2011 7:15 pm
I don't understand the function of parameters "preshared key" and "Enc algo". I set this parameters to user and nothing happen.. The problem is I don't understand how to use this paramaters.
Sorry :(
normis
Fri Jul 08, 2011 7:56 am
Sorry :(
Sergejs clearly posted their function! Is it so hard to read?
Preshared key: This is the WPA key (wireless password)
Enc key: ignore this setting (leave empty)
Fumi
Fri Jul 08, 2011 11:08 am
Ok but how can I use this parameters???
I set a user with a MAC? or I set user with username and password?? This parameters work with hotspot?
Can I configure user demo with this parameters and the connection will be encrypted??
Or not work with hotspot? Only work with wireless? (no hotspot, no ppp, no login)
If work with wireless I need to configure user with MAC address??
I test all this functionalities and any work! I don't say this system not work! Only say that I don't undestand how it work and only I need a help..
Thanks for patience
normis
Fri Jul 08, 2011 11:10 am
your questions indicate that your understanding of networking and RouterOS in general is very low, I advise you to take some mikrotik training course, or watch online tutorials;
http://gregsowell.com/?page_id=951
http://www.tiktube.com/?category=8
Fumi
Fri Jul 08, 2011 11:13 am
And normis I don't need this comments..
I say: The problem is I don't understand how to use this paramaters.
Fumi
Fri Jul 08, 2011 11:14 am
It's so hard to put and example??
Fumi
Fri Jul 08, 2011 11:19 am
Can you post me a videotutorial o documentation how to use this settings? It's only I need!
sergejs
Fri Jul 08, 2011 11:21 am
Look at the picture attached, it shows required configuration on client router (Winbox configuration).
Preshared key is number 2 on the picture;
Enc Algo is number 1 on the picture.
Additional configuration required between router and User Manager,
Fumi
Fri Jul 08, 2011 11:28 am
Thanks sergejs,
this type of configuration only work on client mikrotik devices?
On AP configuration --> http://wiki.mikrotik.com/wiki/User_Mana ... ss_Example --> in security profile I leave Mode: none?
I test this configuration and thanks
sergejs
Fri Jul 08, 2011 11:31 am
No, it works for other OS too.
For example on Windows, AES will be selected automatically and you will need to enter Network Key (the same as PreShared key at User Manager).
You have to use mode=dynamic-keys for WPA/WPA2.
Fumi
Fri Jul 08, 2011 11:41 am
Then If I put in AP dynamic Keys WPA2-PSK and aes.com I need to put WPA2 Pre-Shared Key.
In client I need to configure WPA2 Pre-Shared Key.
If I put PreShared Key in client and AP... The wireless settings in usermanager don't have utility no? Or the functionality is for Radius server to know the preshared key and they can authenticate MAC-addres??
sergejs
Fri Jul 08, 2011 1:43 pm
Fumi,
Setup,
User-Manager <> AP <> Client
AP configuration,
Use the same security-profiles configuration + mode=dynamic-keys set additionally.
Users browsing this forum: No registered users and 7 guests
