krasi9220
I can't access user manager 5.7 from web!
Fri Oct 21, 2011 7:25 am
I have Routerboard 750 and upgrade to 5.7 and installed user-manager 5.7. After that web access for user-manager doesn't work.
sergejs
Re: I can't access user manager 5.7 from web!
Fri Oct 21, 2011 5:36 pm
Try public_IP_address/userman, if HotSpot is installed on the same router.
krasi9220
Sat Oct 22, 2011 11:07 am
I allready try, but doesn't work and I try it behind the hotspot network
bambangs2komputer
Sat Oct 22, 2011 1:34 pm
cek your winbox, ip service port 80 wwww ... there is no input ip. If you input ip.... you must login usermanager with that ip :-)
krasi9220
Sat Oct 22, 2011 6:39 pm
Thanks a lot bambangs2komputer your advice give me the answer.
My IP service list www port 80 was disable.
telstra
Mon Oct 24, 2011 8:33 pm
if ur user manager page will not display simply change wwwport from ip services. then open your.router.com:81/userman
deviant2
Sun Nov 22, 2015 6:05 pm
i've the same problem ...
previously ive RB750 with RouterOS v4 inside, now i just brought new rb RB450G (RI450G-A0) with RouterOS v6, now updated into v.6.33.1, but still didnt work.
my configuration is simple
bridge1: eth3-4=local (dhcp:10.0.254.254/16)
bridge2: eth1-2=hotspot (10.1.254.254/16)
eth5=internet
i use wizard GUI winbox : ip>hotspot>servers:hotspot setup
same exactly setting, like RB750,
can see: login page on bridge2
but cant login into 10.0.254.254/user-manager, it says : "invalid username or password"
i use wizard again : ip>hotspot>servers:hotspot setup > use :
user : adminnew ; pass : password
still cant login
question :
(1) what do i missed ?
(2) (temporary) how to down/upgrade to RouterOS v4 ? (many features missing, like there is no global-in or out)
edit:
SOLVED !?
not working "10.0.254.254/user-manager"
okay "10.0.254.254/userman"
its because of seeing "winbox : system>package" there is "user-manager".
Newbee was here ... !!!
telstra
Sat Apr 23, 2016 9:31 am
open terminal type tool user manager customer print and there u will see the right username and password of your user manager.
eth5=internet
still cant login
question :
edit:
SOLVED !?
Rushi
Wed Jul 26, 2017 12:27 pm
Hello, configure Hotspot with Radius in mikrotik and its work five days very good then i am facing problem fistely that "Radius server is not responding" i am trying to do every thing that which one suggested by mikrotik expert but still its not resolve, then i am reconfigure mikrotik with Hotspot and Radius but Can the hotspot clients access the User Manager web Interface?
I got the User Manager and the hotspot configured, but when I try to acces the User Manager Web Interface (http://xxx.xxx.xxx.xxx/userman) from one of the Hotspot clients, I get this weting and some time Error 404: Not Found.
Request you to all of please help me for reslve this issue.
Roxan1
Sat Sep 16, 2017 10:21 am
Users browsing this forum: No registered users and 3 guests
