arjuneu
Somebody Help Me Out... UM is really depressing
Tue Nov 15, 2011 4:42 am
I have the following problem. When radius server (UM) disconnects the user the profile assigned to the user is also removed from the user but not from the profiles.
Is there anybody to help me out???
bambangs2komputer
Re: Somebody Help Me Out... UM is really depressing
Tue Nov 15, 2011 8:51 am
C'mon
your validity=1d
your uptime=2h
your limitation time=0:00:00-8:13:59
the time 0:00:00-8:13:59 in just 1 day, in other day username test1 can't login
if username test1 login at 1:00:00, user test1 session timeout at 3:00:00.
try to your validity=1w
your limitation uptime=5d
time same with config 0:00:00-8:13:59
Sorry my english
arjuneu
Tue Nov 15, 2011 9:18 am
C'mon
your validity=1d
your uptime=2h
Sorry my english
Is that so, I have users,
Validity=30d
Uptime=Unlimited
time config=00:00:00-7:59:59
I have 7 users for that config, I am getting the same problem. The snapshot is just for testing purpose. I give this account for the users who want to test my internet connection before buying a package.
bambangs2komputer
Tue Nov 15, 2011 4:57 pm
:lol:
by the way your profile config
starts:now
have you try starts: at first logon?
I want to know your winbox so:
/system clock print
/system ntp client print
and after login usermanager click your router, for secure don't forget blur ip address and shared secret. I want to know your time zone
arjuneu
Wed Nov 16, 2011 4:57 am
/system clock> print
time: 08:33:28
date: nov/16/2011
time-zone-name: Asia/Kathmandu
gmt-offset: +05:45
/system ntp client> print
enabled: yes
mode: unicast
primary-ntp: 65.55.21.22
secondary-ntp: 0.0.0.0
status: synchronized
arjuneu
Wed Nov 16, 2011 5:07 am
I also tired with
starts: At First Logon
But it doesn't works.
bambangs2komputer
Wed Nov 16, 2011 6:37 am
I also tired with
ok, you don't have problem with time zone
limitation time just 0:00:00-8:13:59, why you enable CoA support? I got problem with CoA support because nothing time left user in winbox.
If your choice starts:now, accountime begin after you created user
If your choice starts:At first Logon, accountime not begin before user login but you still know when you created user (check payment, example user test1)
More detail user login/logout you can see in session and search type user test1 etc.
My user still can login in other day. My problem just report payment (I have check different payment UM v5.6- v5.8 and compare with excel program. in report payment choice total&price is wrong )and if user like you (I mean user test1) login at 07:00:00-09:00:00 without logout user test1 still access internet. Just waiting routerOS v5.9 or above :-)
arjuneu
Wed Nov 16, 2011 11:17 am
I also tired with
If you use the CoA, the user will be logged out at 9:00:00, but using CoA, you can't find the time left of user in the hotspot user page, if you had it there.
bambangs2komputer
Wed Nov 16, 2011 3:58 pm
If you use the CoA, the user will be logged out at 9:00:00, but using CoA, you can't find the time left of user in the hotspot user page, if you had it there.[/quote]
No, I have tried 3 days ago with enable CoA. my user still not logout, not just that actual profile my user gone. Than I config with time 0:00:00-07:00:00 with validity:30d and uptime:30d without enable CoA. If my user know login at 05:00:00 without logout they have free access. but if at 08:00:00 user logout they can't login againt till 0:00:00. I think this my risk (I hope my user do'nt know about that :lol: ).
I don't know why, maybe from my config. I have 2 different login and different ip and pppoe (all user from Usermanger). If my user login hotspot user can't login with pppoe, if my user login by pppoe they can't login hotspot. I use queuetree pcq for limitation bandwith
I hope RouterOS v5.9 or above fix the issue.
arjuneu
Thu Nov 17, 2011 8:33 am
I hope RouterOS v5.9 or above fix the issue.[/quote]
That means, if I disable the CoA, the actual profile of my users wouldn't be lost. Are you suggesting that??? If so, I will try that too.
arjuneu
Thu Nov 17, 2011 10:19 am
Solved....
Disabling the CoA doesn't solve my problem.
But, I made a script to logout active session of hotspot user and schedule it to run before the UM does.
mohsenettehadi
Thu Feb 09, 2012 10:01 pm
hi
I have same problem so would you please send the script to solve my problem
macsrwe
Forum Veteran
Forum Veteran
Mon Feb 13, 2012 2:59 am
I have a hard time following this discussion, but I believe the script they refer to may do the same thing described here:
http://forum.mikrotik.com/viewtopic.php?f=9&t=28917
arjuneu
Tue Feb 14, 2012 9:15 am
hi
http://forum.mikrotik.com/viewtopic.php ... e+disabled
try this
mohsenettehadi
Fri Feb 17, 2012 10:44 pm
Tank you For Honey Reply.
I update my RB750 V5.13 but the problem is.
because i have various group(10-12,13-14,8-12, . . .) i can not use script.
I AM VERY SORRY FOR MIKROTIK SUPPORT WITH THIS BAD BUG AND DISAPPOINTED FROM UM SO I SHOULD USE ANOTHER USER ACCOUNT SOFTWARE.
mohsenettehadi
Mon Feb 20, 2012 5:16 pm
I send an email to support@mikrotik.com about the problem and recive below reply:
You have profile for one hour. After profile is expired, you need to assign new
profile to the particular client.
Regards,
Sergejs
Come to the MUM in Poland
March 15-16, 2012
http://mum.mikrotik.com/
their mean is this not a problem!!!!!!!
so what do i do??????
Users browsing this forum: No registered users and 7 guests
