aislecom
5.18 userman sending cpu usage to 100%
Tue Jun 26, 2012 3:46 am
Every time I login to userman it takes for ever to do any thing and my cpu usage goes to 100%.
I am running hotspot on the device with two wan connections. I turned off ftp, telnet and ssh to prevent hack attacks.
Dave
antwal
Re: 5.18 userman sending cpu usage to 100%
Sun Jul 08, 2012 4:09 pm
i have the same, problem, my routerboard RB450G, after three days are crashed and stop to work, I would like to return to the previous version but do not know how to do....
I have upgrade from 5.8 version to 5.18 (cpu load is always at 100%) :(
Thanks.
druytssa
Tue Jul 17, 2012 2:54 pm
Check your logs on userman and the amount of disk space left.
To sort this out, make a backup of your userman data.
Remove Userman package.
Remove Userman store
Reinstall everything plus your backup.
On your new userman make sure all log's are disabled.
That will help.
janisk
Tue Jul 17, 2012 4:03 pm
what does /tool profile show when the usage is 100%
also, what pps and what is traffic volume passing through the router?
kthameen
Sun Sep 23, 2012 1:00 pm
Same here we have around 50 mikrotiks with same issue we went back to 4.17, on X86 with corei7 also same problem I donnou whats going on with mikrotik, they lost us 2 days of work and customers complaint after upgrading to v5.20
Users browsing this forum: No registered users and 6 guests
