MUM Europe 2020
yamenh
invalid password users created from usermanager
Tue Oct 15, 2013 11:57 pm
hi
I configured my mikrotik and installed the usermanager
it was working well but after two days it is just got crazy
I tried to create a new users with password and when the client try to log in it is just giving this message "invalid password" what's wrong I don't know
note that the old accounts still working well but now I can't create any new accounts
please help
thanks
codeck
Re: invalid password users created from usermanager
Wed Jun 10, 2015 6:59 pm
hi
please help
thanks
I've the same problem, no answer yet
dannyboy
Fri Oct 02, 2015 11:44 am
I have the same issue, but I spent money on creating 3,000 prepaid scratch off cards. I have read this issue on another thread but also with no response. I bought a rb11002xh for this with the 6 level license specially for this and now this happens.
I hope someone gives us a hand...
mousa1983
Sun Oct 04, 2015 6:17 pm
Hi
change userman password in winbox via terminal
/tool user-manager customer>set password=****
number=0
Dr.Geyonk
Mon Oct 05, 2015 5:25 am
What version do you use?
dannyboy
Mon Oct 05, 2015 8:47 am
I was using 29 but since this happened I switch to the latest one. Ok when I say customers I mean my clients on the street that buy the prepaid cards not Customers as distributors..
Any Idea guys?
mousa1983
Tue Oct 06, 2015 9:22 pm
What's your license level?
4?
5?
6?
dannyboy
Thu Oct 08, 2015 8:27 am
Level 6. I found out the problem. User manager has a glitch. If you create a profile on the user manager and then remove it, it no longer shows you the profile on the user manager. I'd you go to the terminal on the winbox or login via telnet and goto tools user-manager profile profile limitations you will find that the profiles are still there.
My problem was that I did some testing profiles with the same name, after I removed them, I created the profile I was going to use. Since ask my test profiles and my real profile had the same name, users kept getting transfer from one to the other profiles.
To bad I found this out after I deleted all 3000 accounts I had created.
Hope this helps since none had ever posted a solution for this issue.
Almadhaji
Fri Nov 20, 2015 1:30 pm
Hi dannyboy,
could you please support your great solution with snapshots as I could not find how to remove them in Mikrotik?
Users browsing this forum: No registered users and 3 guests
