MUM Europe 2020
csickles
2.9.27 released
Mon Jul 03, 2006 5:01 pm
Look out all of you testing the UserManager...
The User Manager Package still shows .26
If you upgrade you will loose your usermanager..
Hold off upgrading untill UserManager is updated..
Craig
lastguru
Trainer
Trainer
Mon Jul 03, 2006 5:32 pm
2.9.27 userman is up now. you can try to upgrade
dolf
Mon Jul 03, 2006 8:09 pm
I problem I saw in the previous vesion and I still see it in 2.9.27.
When you go to status and View active users and try to sort by the different fields it only seems to work with the usersname field. I would be useful to sort by uploads, downloads and uptime. I think it was ntended to work that way.
It is still a great program!
uldis
Wed Jul 05, 2006 10:40 am
thank you for the report, in the next version we will have a fix.
airstream
Sun Jul 09, 2006 1:11 am
...I would be useful to sort by uploads, downloads and uptime...
This woule be great, at my ISP we allocate by data chunks per month, not hotspot based time limit. To have the ability to list the users by data used since last counter reset would be great.
Are we any closer to a wildcard command for counter-reset to reset the counters for all users with "one click"? rather than entering each number in terminal.
Great work on the User manager!!
Geoff
Users browsing this forum: No registered users and 7 guests
