wytco0
Request for sample script
Wed Oct 21, 2015 1:28 pm
Hi I am struggling to reconfigure my RB2011 to use port 10 as the WAN connection (with PPPoE).
Could someone post a script or a link to something similar to help me configure my router to:
use Port 10 for WAN.
configure PPPoE to use port 10
Configure DHCP to use 192.169.100-200 as addresses
I am sure this is pretty simple but I don't know where to start and a sample script would enable me to have a play.
scampbell
Trainer
Trainer
Re: Request for sample script
Wed Oct 21, 2015 11:51 pm
# remove ether10 from switch group (usually master-port=ether6)
1. /int eth set [find name=ether10] master=none
# create pppoe-client on ether10
2. /int pppoe-client add name=pppoe-out1 interface=ether10 user=changeme password=changeme use-peer-dns=yes add-def=yes dis=no
# add NAT rule to pppoe-client
3. /ip firewall nat add chain=srcnat out-int=pppoe-out1 action=masquerade
# add your firewall rules to protect rouyter and lan (in-interface=pppoe-out1
4. add you firewall rules here !!
# create your new pool, assumes you have existing matching IP and DHCP etc.
5. /ip pool add name=pool-new ranges=192.168.9.100-192.168.9.200
6. edit your DHCP Network to use this new pool
Hope this helps :D
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
wytco0
Thu Oct 22, 2015 12:00 am
Hope this helps :D
Thanks I will give this a try.
Users browsing this forum: Majestic-12 [Bot] and 32 guests
