tionck
Connect to my public IP inside my LAN
Mon Nov 09, 2015 12:36 pm
Hello everyone.
Here is my case;
I setup firewall rules to open specific ports, everything is working on it. I can connect easily from other places over my public IP, but if I try to connect with my public IP from my LAN, that is in the same RouterBOARD is not working.
I think I'm missing something, should I make some route or IP tunnel to my public IP work inside my LAN?
Sorry for my bad english :(
ericnyamu
Re: Connect to my public IP inside my LAN
Mon Nov 09, 2015 4:36 pm
i think you need to setup your routes correctly. and let the pc know which is the gateway and how to route the ips in and out of the network.
tionck
Mon Nov 09, 2015 5:28 pm
The gateway of my computers are the RouterBOARD.
How I config the route? I try alot of settings, but no one works.
I think in the same way of you eric, but I can't find the correctly settings.
Thanks for reply :)
PaulsMT
Mon Nov 09, 2015 7:48 pm
tionck
Mon Nov 09, 2015 8:22 pm
Thank you very much!
Thats exactly what I'm looking for. :D
Mods can close the topic.
Users browsing this forum: Muqtada and 47 guests
