miltont
Cable Modem Public IP
Wed Nov 11, 2015 5:38 am
Greetings
I have a Cable Modem that i want to connect to a new mikrotik RB750.
I want to assign my dynamic public ip address to my Ethernet1 Interface (WAN Interface), it only gets 192.168.0.3 assigned via DHCP Client.
How can i assign that dynamic public ip on the mikrotik?
If i connect my cable modem to a netgear router and i go to web management interface and go to WAN Setup
i see my dynamic public ip 24.42.28.162 assigned to the wan interface.
pukkita
Trainer
Trainer
Re: Cable Modem Public IP
Thu Nov 12, 2015 2:47 pm
You need to put the Cable modem in bridge mode (google it for your telco provider/cable modem model), then use either DHCP or PPPoE from the mikrotik to get the IP.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
miltont
Fri Nov 13, 2015 2:19 am
Greetings
The modem is already in bridge mode, because it works fine on the netgear....
The mikrotik has DHCP CLient... about the PPPoE how do i check it?
pukkita
Trainer
Trainer
Fri Nov 13, 2015 4:22 pm
Greetings
No need for PPPoE if the netgear is getting the ip by DHCP.
Just add a DHCP client on the Mikrotik WAN interface and you'll be set.
Users browsing this forum: censored224, ksteink and 42 guests
