scinex
Link up master port
Wed Dec 09, 2015 3:57 pm
RB951UI v6.33.3 Firmware 3.24
ether2 - is master port for ether3,4,5.
ether2 is NOT connected.
When i connect link to ether3, 4 or 5, ether2 is upping to 10M, half duplex.
04:06:26 interface,info ether3 link down
04:06:27 interface,info ether2 link down
04:06:28 interface,info ether3 link up (speed 100M, full duplex)
04:06:29 interface,info ether2 link up (speed 10M, half duplex)
04:08:23 interface,info ether3 link down
04:08:24 interface,info ether2 link down
04:08:25 interface,info ether4 link up (speed 100M, full duplex)
04:08:26 interface,info ether2 link up (speed 10M, half duplex)
04:11:30 interface,info ether4 link down
04:11:31 interface,info ether2 link down
04:11:32 interface,info ether5 link up (speed 100M, full duplex)
04:11:33 interface,info ether2 link up (speed 10M, half duplex)
Is it normally work or it's hardware failure?
plisken
Re: Link up master port
Thu Dec 10, 2015 6:50 pm
The network cables are not broken?
Which devices are associated with it?
chechito
Thu Dec 10, 2015 7:02 pm
using eth2 as a master port and eth3 eth4 eth5 as slaves mine do the same but works ok
scinex
Thu Dec 10, 2015 7:22 pm
But it is not clear. It is not clear visualy on the led there is a link at the port or not.
plisken
Fri Dec 11, 2015 9:07 am
Connect a network cable on the questtionable interface.
Connect the network cable to a computer.
Ping from the computer to an IP-adres on the router.
Are there interruptions?
So not, maby a bug in RouterOs
scinex
Fri Dec 11, 2015 9:25 am
PING ok, all work ok.
But IMHO it is incorrect, when cable is not conneted and link on port is up.
If it is a bug, how i can ask this to Mikrotik support?
plisken
Fri Dec 11, 2015 11:16 am
Login with winbox
On the main window click on "make supout.rif
Look to "files" in the main window
drag and drop the file "supout.rif to your PC
Mail Mikrotik to support@mikrotik.com and attache the file
scinex
Fri Dec 11, 2015 11:23 am
Done.
plisken
Fri Dec 11, 2015 12:04 pm
Goodluck
scinex
Fri Dec 11, 2015 12:29 pm
The lit port LED is a cosmetic issue on a Fast Ethernet switch chip due to
"Running" state of the master-port when a link of its slave-port turns on.
It is planned to address this master-port LED imperfection along with other switch
chip changes in RouterOS v7.
Regards,
Thx for all.
Haven't questions anymore.
CrazyCooler
Thu Aug 10, 2017 12:51 pm
Hello! Check ethernet port on PC or Notebook. One non-working port on a computer or laptop can cause all ports on the router to reboot. A non-working port can be checked by an exception method.
Users browsing this forum: Google [Bot] and 24 guests
