chintan1011
Hap lite performance review!
Tue Jan 05, 2016 7:58 pm
I want to use two hap lite for pptp VPN setup ..also want to use these hap lite as WiFi router at both end ..
So I want to know how will be the performance of hap lite in this condition..
Is both pptp and wifi can be configured on same device?
chintan1011
Re: Hap lite performance review!
Wed Jan 06, 2016 1:10 pm
Anybody reply for this who have used this product..its urgent!!
macgaiver
Wed Jan 06, 2016 1:42 pm
Yes, you can use both features at the same time.
I haven't Btested it for performance, but it was sufficient when i used it.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
chintan1011
Wed Jan 06, 2016 2:33 pm
I want to know that if the hardware specification is sufficient for pptp VPN also along with wifi configuration??
chintan1011
Wed Jan 06, 2016 2:37 pm
Moris please share your opinion also!
normis
Wed Jan 06, 2016 2:40 pm
What is the question here? Any device will support VPN. It is not very resource intensive.
Give us more details about what type of VPN you need and how many users you will connect there. Are you actually talking about VPN server or client on the RouterBOARD?
chintan1011
Wed Jan 06, 2016 3:08 pm
Actually I want to configure pptp server client VPN..6 users one side and 4 users second side
normis
Wed Jan 06, 2016 3:23 pm
you could have 100 maybe :) sure, no problem. any RouterBOARD can do it
chintan1011
Wed Jan 06, 2016 3:26 pm
Means wifi and pptp VPN both side
chintan1011
Wed Jan 06, 2016 3:29 pm
So these configuration is not that high resource intensive that hap lite won't support right!?
chintan1011
Wed Jan 06, 2016 3:32 pm
Actually I m in doubt that this device having RAM and hdd will not support this type of configuration!
normis
Wed Jan 06, 2016 3:37 pm
This is not very intensive config. You can have more VPN connections without problems. RAM and HDD space is not relevant for such setup. CPU is fast enough.
macgaiver
Wed Jan 06, 2016 3:39 pm
Wireless AP + NAT + firewall + SNTP + Fasttrack + DNS + uPnP + PPTP server, on 50Mbps connection, no problems what so ever.
I think you need to stop making theories and actual try the thing.
chintan1011
Wed Jan 06, 2016 4:07 pm
:D okayi have to try this in live scenario.. Thanks for you advices both of you..
Actually I was comparing its price and resources with cisco rv042, rb450, rb750 which has higher price that's why I am so much confused.
kiler129
Fri Jan 08, 2016 12:34 am
In Cisco world you even have to pay for extra static routes ;)
A week ago I came across rather beefy 48 port router/switch combo which refused to add 17th static route without additional license costing more than $5k :shock:
Mikrotik world is totally different - limits on licenses are well.... above what hardware can handle ;) No devices are crippled - all devices supports all features (of course except some special features where additional hardware is required, e.g. for hardware switching).
chechito
Fri Jan 08, 2016 1:44 am
maybe a little less than that for vpn performance
i have tested haplite on a ipsec site to site AES-128cbc SHA1 gets a maximum of 29mbit/s with 100% cpu usage
a heavy nat + firewall + mangle + queue tree gets a maximum of 45mbit/s with 100% cpu usage
off course a simpler configuration moves 100mbit/s without problem
ZimboDude
Sun Jan 10, 2016 8:13 am
I recently bought an hAP Lite, configured a hotspot on it at my home for three users, upgraded to the latest firmware and the device never came back up after reboot. Tried resetting it multiple times too and still wouldn't come back up. Eventually swapped it out for an RB-750R2.
kiler129
Mon Jan 11, 2016 11:43 am
(...) Tried resetting it multiple times too and still wouldn't come back up.
You should use http://wiki.mikrotik.com/wiki/Manual:Netinstall than.
ZimboDude
Mon Jan 11, 2016 9:32 pm
Swapped the device for an RB750R2 - working well :)
Users browsing this forum: No registered users and 34 guests
