grey
hAP lite TC - disable ports LED
Wed Jan 13, 2016 3:41 pm
hi, it's a great little router BUT damn the green LEDs are like a torch in the night and they are seen thru the ventilation holes in the case...
is there any way to have them disabled?
chechito
Re: hAP lite TC - disable ports LED
Thu Jan 14, 2016 4:02 pm
black tape and its done :lol: :lol:
Zorro
Long time Member
Long time Member
Thu Jan 14, 2016 8:23 pm
suffer 4om that myself too, MUCH :((
thanks to LED's tech advance - EVERYthing in IT hw - become "miniature projector/searchlight".
display buttons, motherboard(usually many of many colors), coolers, harddrives(especially external. sometimes like "christmass tree". crashy s.., man !!) routers - eventually had as bright LED's too(relying on average "off the shelf" things as other manufacturers do). heck, even my mice - had 9 (9, Carl !!! 9 !!)LED's, whose can be easily disabled for ..(insert by you taste) sake.
in out-door in urban area - its affected too. check "light pollution" or hygiene-relevant light intensity/proximity/directions resctritions(usually daytime-bound/tweaked), violated on persistent basis aswell.
p3rad0x
Long time Member
Long time Member
Fri Jan 15, 2016 6:45 pm
I think you can disable the led's by removing all entries under system ---> led's menu
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
grey
Fri Jan 15, 2016 6:48 pm
i have 0 items under that menu.
G2Dolphin
Sun Jan 17, 2016 8:17 am
hAP lite have only "user-led". I've seen only one device, when ALL leds can be configured (except power, of course) — mAP.
Home: RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, GrooveA-52HPn, hEX (r3), hAP lite, RB951G-2HnD
Work: RB2011UiAS-RM / UiAS-2HnD-IN, RB951G-2HnD, hEX (r3), CRS125-24G-1S-2HnD-IN, CCR1009-8G-1S-1S+
Users browsing this forum: No registered users and 24 guests
