MUM Europe 2020
Sharkec
No green light on ethernet port
Thu Jan 14, 2016 9:01 pm
I have problems with connecting some LAN devices to CCR1009. If I connect PC to any port on CCR I get IP from DHCP and green light is on and amber light is flashing.
But If I connect to any port other equipment media-player, sat-receiver... then only amber light is flashing slowly, green light is OFF and DHCP does not supply IP to those devices.
If I connect devices to RB2011 they works normal.
Is there something with settings?
p3rad0x
Long time Member
Long time Member
Re: No green light on ethernet port
Fri Jan 15, 2016 6:36 pm
you can check if the ethernet ports are set to auto negotiate their link speed.
Also is the same thing happening when you plug both ends of the same cable into the router?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
fibernetwork
Sat Jan 16, 2016 5:37 am
Check auto-negotiation of your Ethernet ports.
Fiberstore -James
Sharkec
Sat Jan 16, 2016 4:06 pm
I tried with auto negotiatio ON and also OFF and manual settings but no success.
asaleh75
Trainer
Trainer
Sat Jan 16, 2016 11:38 pm
Green light will on when you connect to a gigabit ethernet port.
Syed Abu Saleh
( MTCNA, MTCRE, MTCWE, MTCTCE, MTCUME, MTCINE )
MikroTik Certified Trainer & Consultant
http://www.sastechbd.com
Cell:+8801713060704
Sharkec
Tue Jan 19, 2016 8:04 pm
Tnx:)
Users browsing this forum: No registered users and 44 guests
