stefanpeeters1981
Email settings
Fri Jan 29, 2016 1:27 am
I like to get email alerts in my mailbox when something goes wrong with my router. I do not know how to set this up (gmail) in mikrotik. I am new whit this brand so if anyone can help me with this I would be very thankfull.
rjscomms
Re: Email settings
Fri Jan 29, 2016 11:43 am
stefanpeeters1981
Re: Email settings
Fri Jan 29, 2016 12:32 pm
Thanks for the reply. Yes I have done this but I don't get any emails in my inbox. Don't know what I am doing wrong. By address I type in one of the addresses I got when doing a nslookup to gmail.com
I have tried all the addresses I got
Greatings
plisken
Re: Email settings
Fri Jan 29, 2016 7:13 pm
See on my website.
You see there email settings with Pop3 and Gmail
http://www.wirelessinfo.be/index.php/mi ... ges/emaile
stefanpeeters1981
Re: Email settings
Sat Jan 30, 2016 1:18 am
See on my website.
Thanks for the answer but it still doesn't work.
I wil post my settings
Server: 74.125.47.27
Port: 465
Start TLS: no
User: peeters1981(at)gmail.com
Password: xxxxxxxx
Than when I click apply and after Send Email I get another screen that pops up and I fill out the empty fields:
Adres: 74.125.47.27
Port: 465
Password: xxxxxxx
TLS:no
To: peeters1981(at)gmail.com
CC:
Subject: Test
Body:
File: Latest backup
I found the ip addres by doing a nslookup from smtp.gmail.com
plisken
Re: Email settings
Mon Feb 01, 2016 12:41 pm
Try with IP 74.125.136.108 port 587
start TLS YES
stefanpeeters1981
Re: Email settings
Mon Feb 01, 2016 7:55 pm
start TLS YES
Thanks for trying to help me but with te sugested changes it doesn't work yet. This is what I do:
Email Settings
I click on tools - Email
Then in the email settings I fill this out:
Server: 74.125.136.108
Port: 587
Start TLS: yes
User: peeters1xxatgmail.com
Password: *********
Send Email
Address: 74.125.136.108
Port: 587
User: peetersxxxatgmail.com
Password: ********
TLS: yes
To: centralatlastresort.be
CC:
Subject: Test
Body:
File: (latest backup)
Hopefully you find something I do wrong :?
scampbell
Trainer
Trainer
Re: Email settings
Wed Feb 03, 2016 12:24 am
Add a topic=e-mail action=memory to your /system logging.
The additional log info should help show what is not working correctly when you send an e-mail :-)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Dobromyr
Re: Email settings
Wed Feb 03, 2016 2:11 pm
start TLS YES
Email Settings
Port: 587
Start TLS: yes
Password: *********
Send Email
Port: 587
Password: ********
TLS: yes
CC:
Subject: Test
Body:
Try copy peetersxxxatgmail.com to CC: field
Dobromyr
Re: Email settings
Wed Feb 03, 2016 2:12 pm
Try
CC: peetersxxxatgmail.com
work for me
Dobromyr
Re: Email settings
Wed Feb 03, 2016 2:18 pm
I have other problem
I dont save email settings
Apply - good
Logout MT -> Login MT - email Server - 0.0.0.0
WinBox v6.34
scampbell
Trainer
Trainer
Re: Email settings
Thu Feb 04, 2016 10:44 pm
Please try setting your e-mail server using the CLI. We have found setting this in Winbox does not work in the RoS 6.34 or 6.33.5 and reported it to Mikrotik.
/tool e-mail set address=x.x.x.x
___________________
stefanpeeters1981
Re: Email settings
Fri Feb 05, 2016 10:10 am
start TLS YES
Email Settings
Port: 587
Start TLS: yes
Password: *********
Send Email
Port: 587
Password: ********
TLS: yes
CC:
Subject: Test
Body:
I wanna thank you all for all the good help! I added the CC field and It works.
Thanks again! :D
plisken
Re: Email settings
Fri Feb 05, 2016 5:26 pm
Well done and thanks for the info
Users browsing this forum: No registered users and 32 guests
