igpetkov
High CPU Load
Mon Feb 01, 2016 9:37 pm
Hi, All!
I have a problem with my BR750GL, the CPU load is very high. In Profile I see that "dns" usage is 80-90%.
When I stop "Allow Remote Request" the usage go down. Can someone explain that.
Can I fix that problem?
Thank you
darkprocess
High CPU Load
Mon Feb 01, 2016 10:49 pm
Dns attack?
IPANetEngineer
Trainer
Trainer
Re: High CPU Load
Mon Feb 01, 2016 11:09 pm
Hi, All!
Thank you
What you are seeing is most likely a DNS amplification attack or some variant of it.
https://www.us-cert.gov/ncas/alerts/TA13-088A
It's a very easy fix. Either don't allow remote requests or put the following rule in your firewall above all other rules on the input chain.
add action=drop chain=input dst-port=53 protocol=tcp
add action=drop chain=input dst-port=53 protocol=udp
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
chechito
Re: High CPU Load
Mon Feb 01, 2016 11:32 pm
i think to the rules IPNET posted you have to add some rule to allow internal users to query dns cache on mikrotik
jarda
Wed Feb 03, 2016 8:31 am
Sure. The rules have to be port specific otherwise it's better to switch dns service off. When such rules are needed it means your firewall has conceptual error. Think of it.
igpetkov
Re: High CPU Load
Wed Feb 03, 2016 8:30 pm
Thank You, about your advices and about my long absence.
By adding two firewall rules cpu overload has stop:
chain=input action=drop protocol=tcp in-interface=ether1 dst-port=53 log=no log-prefix=""
chain=input action=drop protocol=udp in-interface=ether1 dst-port=53 log=no log-prefix=""
I keep an eye on my router and post here result.
Thank you again
IPANetEngineer
Trainer
Trainer
Re: High CPU Load
Thu Feb 04, 2016 5:26 pm
Thanks for the catch...I do normally add an input interface to the rule :D
Users browsing this forum: dioeyandika and 43 guests
