PeterLemmen
IPsec site 2 site VPN. Ping fails in one direction.
Fri Feb 05, 2016 8:48 am
I've configured an IPsec Site 2 site VPN connection between a public Cloud and my on premise environment. Weird thing: PING only works in one direction. I'm able to ping from my on premise environment to virtual machines in the Cloud.
But when I try to ping from the Cloud to my machines on premise it fails.
I don't think it is a firewall problem because a ping from the Cloud side to the Mikrotik router on premise is succesfull:
Maybe the reply of the device behind the Mikrotik router somehow gets lost and is not delivered at the device that initiated the ping on the public cloud side. A routing problem? Shouldn't this be covered by the config of the VPN at the Mikrotik side (IPsec policy)?
Probably something tiny I missed somehow. But what did I miss or do wrong? Hope someone is able to help.
Thanks in advance.
Peter
Revelation
Re: IPsec site 2 site VPN. Ping fails in one direction.
Fri Feb 05, 2016 2:58 pm
Without seeing more details, it looks like you need to ensure that you have a route back across the tunnel for the return traffic.
BartoszP
Fri Feb 05, 2016 4:19 pm
Check this @ 3/4 of text or search "Site to Site IpSec Tunnel": http://wiki.mikrotik.com/wiki/Manual:IP/IPsec
Real admins use real keyboards.
PeterLemmen
Fri Feb 05, 2016 6:25 pm
What kind of route should that be? I could not find a requirement for adding a specific route for return traffic in the guidelines. I've used this part of the Mikrotik manual as reference: http://wiki.mikrotik.com/wiki/Manual:IP ... Sec_Tunnel
jaytcsd
Sun Feb 07, 2016 8:41 am
I had the same problem, switched to EOIP tunnels and made both sites the same IP range, working fine now.
PeterLemmen
Tue Feb 09, 2016 10:43 pm
Thanks for your help! The other side of my Site 2 site connection is Microsoft Public Cloud Azure. I don't think they are supporting EOIP tunnels. Is there an alternative to solving this issue, I can do on the MikroTik side without the need to change technologies or protocols at the Microsoft side?
Peter
PeterLemmen
Tue Feb 09, 2016 10:44 pm
Да, это неплохой вариант.
Bedankt!
jaytcsd
Fri Feb 12, 2016 9:47 am
I have never tried a tunnel from a Mikrotik to any other router.
Greg Sowell has examples of IPsec and IPIP tunnels from Mikrotik to Cisco on his site.
http://gregsowell.com/?p=1290
PeterLemmen
Mon Feb 15, 2016 11:07 pm
Yes I know the site of Greg. Followed some of his video's. The weird thing is it's almost working perfect. I can even ping my router from the public cloud (azure) side. I recently changed all IP spaces on public cloud side so they are now more similar to the on premise side. But all though everything was changed and re-configured with the new IP space the result is still exactly the same:
1) Ping from Azure VM to Mikrotik router is succesfull
2) Ping from device behind Mikrotik router to Azure VM is succesfull
3) RDP session from device behind Mikrotik router to Azure VM is succesfull
4) Ping to on premise device (behind the Mikrotik router) from Azure VM fails
ekobravo
Tue Feb 16, 2016 2:35 pm
Did you find the solution?
I have the same problem. I've configured an IPsec Site 2 site VPN connection between HQ and remote office. I’m using RB2011iL-IN in both offices. PING only works in one direction. I'm able to ping from my on HQ to remote office. Not just that I'm able to connect to any pc from the HQ to remote office. From remote office I can not ping or connect to for example MainServer.
Thanks in advance.
PeterLemmen
Tue Feb 16, 2016 2:42 pm
Thanks in advance.
Hi Ekobravo,
No solution yet. As you have the same issue maybe it's not supported on the MikroTik side or some kind of bug in the MikroTik router product?
PeterLemmen
Tue Feb 16, 2016 3:54 pm
This is the configuration on MikroTik side I'm using:
# feb/16/2016 14:01:57 by RouterOS 6.33.5
/ip ipsec policy group
set
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=aes-128-ctr lifetime=10m \
pfs-group=none
add enc-algorithms=3des lifetime=1h name="Azure Site 2 Site VPN" pfs-group=\
none
/ip ipsec peer
add address=*.*.*.*/32 enc-algorithm=3des nat-traversal=no secret=\
******* send-initial-contact=no
/ip ipsec policy
set 0 disabled=yes dst-address=0.0.0.0/32 src-address=0.0.0.0/32
add dst-address=192.168.4.0/22 proposal="Azure Site 2 Site VPN" \
sa-dst-address=*.*.*.* sa-src-address=*.*.*.* src-address=\
192.168.0.0/22 tunnel=yes
ekobravo
Tue Feb 16, 2016 5:19 pm
I'm using similar configuration. Try so far probably 4-5 times with even different routers. This is my first IPces configuration. I managed to setup PPTP, EOIP, EOIP over PPTP etc. (for different customer) and it's working fine.
This is what I don't get. Why MikroTik help doesn't want to help? It is beyond believe. If is something (like for example) hardware doesn't support this they should come and say it. Or if there is solution... they should know...tell us. It is unbelievable.
Thanks for your reply look like we are on our own on this.
P.S. If you find solution please post it. THANKS
jaytcsd
Wed Feb 17, 2016 10:05 am
These are sites I looked at when I was trying to get IPsec tunnel working. I noticed most seemed to be version 5 software, maybe that's the key.
http://wiki.mikrotik.com/wiki/Securing_ ... _for_IPSec
https://www.youtube.com/watch?v=oR4G6SZ3LcM
https://www.youtube.com/watch?v=y68Dx8iPikA
https://www.youtube.com/watch?v=UZ2pIC0EuHs
HansHinnekint
Wed Feb 17, 2016 1:07 pm
I'm a bit further than that: I can ping in both directions but not yet really use it:
This is the config:
Home Range: 192.168.1.0/24
Azure Network Range: 10.200.0.0/16
My Pubic IP: 81.3.30.135
Azure gateway IP: 140.13.104.73
These are my settings:
/ip ipsec peer
add address=140.13.104.73/32 dpd-interval=disable-dpd enc-algorithm=aes-256 \
lifetime=1h secret=VeryDeepSeCret!
/ip ipsec policy
add dst-address=10.200.0.0/16 sa-dst-address=140.113.104.73 sa-src-address=\
81.3.30.135 src-address=192.168.1.0/24 tunnel=yes
add chain=input comment="Allow from Azure" log=yes protocol=ipsec-esp \
src-address=140.13.104.73
add chain=forward in-interface=Internet-Outside src-address=10.200.0.0/16
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related
add action=drop chain=input comment="default configuration" in-interface=\
Internet-Outside log=yes
add action=fasttrack-connection chain=forward comment="default configuration" \
add chain=forward comment="default configuration" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid log=yes
connection-nat-state=!dstnat connection-state=new in-interface=\
add chain=srcnat comment="Azure VPN Tunnel" dst-address=10.200.0.0/16 log=yes \
add chain=dstnat comment="Azure VPN Tunnel" dst-address=\
192.168.1.0/24 src-address=10.200.0.0/16
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=Internet-Outside
Still struggling on using basic things like RDP over this connection.
ekobravo
Wed Feb 17, 2016 2:05 pm
I'm using version 6.34.1
I can ping from HQ router everything but from remote office I can ping only HQ router.
I did try to add ipip with ipsec but it is doing the same thing. I think we are missing some routing here but I'm not sure what. I can also ping in both directions but only routers IP nothing else.
I'm at the point that I will probably get cisco routers and finish the job. I can not understand why Mikrotik is not helping. Forum should be the place that we are helping one to another. But if there is no right answer or solution Mikrotik should jump in. They should help. We are buying their product. We are using their product.
Where is the logic (read future) here?????
HansHinnekint
Wed Feb 17, 2016 2:47 pm
Well, I think you need to add the source NAT rules (like in my sample above) to make it work.
ekobravo
Wed Feb 17, 2016 3:26 pm
I have this
add chain=srcnat comment="VPN Tunnel" dst-address=192.168.17.0/24 log=no \
src-address=172.16.20.0/24
out-interface=WAN
HansHinnekint
Wed Feb 17, 2016 5:59 pm
I have this
out-interface=WAN
I just had a word with Mirotik Support and they were really helpfull:
What I needed to do is:
/ip ipsec peer
/ip ipsec policy
add chain=forward comment="Allow from Azure" dst-address=10.200.0.0/16 \
place-before=0
/add chain=forward dst-address=192.168.1.0/24 src-address=10.200.0.0/16 \
place-before=0
/add chain=input comment="Allow from Azure" log=yes protocol=ipsec-esp \
src-address=140.113.104.73
place-before=0
Now everything works fine ;-)
ekobravo
Wed Feb 17, 2016 6:52 pm
Thanks for reply I'll try this and let you know, :D
ekobravo
Wed Feb 17, 2016 7:08 pm
For me still not working:
This is what I put:
add chain=forward comment="" dst-address=192.168.17.0/24 \
add chain=forward comment="" dst-address=172.16.20.0/24 \
src-address=192.168.17.0/24
it is place-before=0
out-interface=WAN
HansHinnekint
Wed Feb 17, 2016 7:17 pm
This is what I put:
out-interface=WAN
I got help from Mirotik after a mail to support@mikrotik.com (Maris B.) he was really helpfull
ekobravo
Wed Feb 17, 2016 7:22 pm
Is it possible that "fasttrack dummy rule" makes mess in firewall,what do you think? I have on one router but not on another one.
HansHinnekint
Wed Feb 17, 2016 9:54 pm
According to the support guy 'We have to accept the traffic in firewall that should go through the ipsec tunnel before the fasttrack rule.'
this is why the place-before=0 is required
ekobravo
Wed Feb 17, 2016 10:19 pm
I know but I can not place the ipsec tunnel before the fasttrack rule. I can not even delete fasttrack rule. I'm just searching forum to find out how to remove or disable this rule but looks like it is not possible. Anyhow, thanks.
scampbell
Trainer
Trainer
Wed Feb 17, 2016 10:37 pm
To get rid of fasttrack there is a firewall rule created by default directly below the two rules to allow established and related with an action=fasttrack-connection.
The rule looks like this:-
"add action=fasttrack-connection chain=forward comment="default configuration" \
connection-state=established,related"
Delete this then reboot your router - the dynamic rules should no longer be present.
If your VPN is only working one way try disabling (temporarily) any drop rules in the firewall. Does it now work ? If yes then you need to ensure your VPN traffic is allowed in. It's incoming interface is the WAN interface (perhaps ether1 or pppoe-out1? )
Dont forget to re-enable your drop rules after this !!!
Enabling logging on any drop rules may also be helpful.
Also check any dst-nat rules are not catching your IPSEC traffic. Disable them while testing or make them very specific by specifying a dst-address that is your WAN address.
Lastly download and read the Packet Flow Diagram - it is very helpful in understanding how IPSEC is processed through the router.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
PeterLemmen
Thu Feb 18, 2016 9:54 am
Thank you scampbell for your useful tip to temporary disable firewall rules. I disabled them one by one and found out the following rule from the default configuration was blocking my ping from Microsoft Azure to on premise network:
ether1-gateway
I was also earlier in contact with Maris B. from support. He pointed me to the following information on the MikroTik WIKI: http://wiki.mikrotik.com/wiki/Manual:IP ... d_proposal
You can find there that you need to put in the NAT Bypass. I think what is missing is you ALSO have to add a Firewall Filter Rule to allow the traffic from the remote side to forward into your on premise network. This was blocked by the above rule in my MikroTik router that I put in my router during initial setup and at that time (and still does) makes sense.
Could not find anything about this in the MikroTik WIKI link I shared above. But that's ok because at least now I could figure out what I needed to solve this problem. I just allow the subnet in Microsoft Azure to communicate with the subnet on premise with this single line and put it on top of the Filter rules:
add chain=forward comment="Allow from Azure" dst-address=192.168.0.0/22 \
src-address=192.168.4.0/22 place-before=0
Problem solved, everything working now.
Thanks a lot guys for your help!
Cheers,
Peter
mrz
Thu Feb 18, 2016 11:26 am
Not only that, but also fast-track rule affects ipsec traffic. So for tunnel mode to work properly you need to allow tunnelled traffic before fast-track or rule with connection-nat-state=!dstnat.
ekobravo
Thu Feb 18, 2016 4:13 pm
And how can I do this? If I try yo move firewall rule before fast-track rule I'm getting this error message:
"Couldn't move Firewall Rule <172.16.20.0/24->192.168.17.0/24> -cannot move builtin(6)"
If I try to delete this is what I'm getting:
""Couldn't move Firewall Rule <> - -cannot move builtin(6)"
So, is it the only way to reset configuration, remove configuration and start from beginning?
mrz
Fri Feb 19, 2016 12:11 pm
Not sure what exactly you are trying to move, but none of my mentioned rules are built in. They are created either by default configuration or by user.
HansHinnekint
Fri Feb 19, 2016 12:18 pm
This is done by the place-before=0 option
This is what works for me:
src-address=192.168.1.0/24 place-before=0
place-before=0
ekobravo
Fri Feb 19, 2016 5:12 pm
place-before=0
Problem also solved, everything working now.THANKS
arovah
Wed Aug 31, 2016 11:15 am
Hi guys,
I have same issue. If i ping from mikrotik to vm cloud was failed but if i test ping from vm cloud to my mikrotik was success.
I have set firewall nat in mikrotik :
add chain=srcnat action=accept place-before=0 src-address=10.62.1.0/24 dst-address=192.168.62.0/24
And add firewall filter :
add chain=forward dst-address=10.62.1.0/24 src-address=192.168.62.0/24 place-before=0
add chain=forward dst-address=192.168.62.0/24 src-address=10.62.1.0/24 place-before=0
This is my ip for vm cloud :
ip public : 119.202.xxx.xxx
ip private : 192.168.62.0/24
This is my ip for mikrotik :
ip public : 202.202.xxx.xxx
ip private : 10.62.1.0/24
Please any solution ? Thanks in advance
phatone007
Wed Mar 14, 2018 12:09 am
I have this
out-interface=WAN
/ip ipsec peer
/ip ipsec policy
place-before=0
place-before=0
place-before=0
This worked me me!
Bas2033
Sat May 05, 2018 2:08 pm
Same problem here. Unfortunately the solution #34 describes doesn't work for me.
Here is my config:
0 ;;; Allow from Local to Azure intern
chain=forward src-address=192.168.6.0/24 dst-address=10.0.0.0/16
1 ;;; Allow from Azure intern to Local
chain=forward action=accept src-address=10.0.0.0/24 dst-address=192.168.6.0/24 log=no log-prefix=""
2 ;;; Allow from Azure extern
chain=input protocol=ipsec-esp src-address=52.233.x.x log=yes
0 ;;; VPN Tunnel to Azure
chain=srcnat action=accept src-address=192.168.6.0/24 dst-address=10.0.0.0/16 log=no log-prefix=""
1 ;;; VPN Tunnel from Azure
chain=srcnat src-address=10.0.0.0/16 dst-address=192.168.6.0/24 log=no
2 ;;; default configuration van forum
chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
/ip ipsec policy
0 A src-address=192.168.6.0/24 src-port=any dst-address=10.0.0.0/16 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=213.127.x.x sa-dst-address=52.233.x.x
proposal=default ph2-count=1
1 T * group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
/ip ipsec/peer
0 address=52.233.x.x/32 auth-method=pre-shared-key secret="secret" generate-policy=no policy-template-group=default exchange-mode=ike2 send-initial-contact=yes hash-algorithm=sha1 enc-algorithm=aes-256,aes-128
dh-group=modp1024 lifetime=8h dpd-interval=disable-dpd
1 R address=::/0 auth-method=pre-shared-key secret="" generate-policy=no policy-template-group=default exchange-mode=main send-initial-contact=yes nat-traversal=yes proposal-check=obey hash-algorithm=sha1
enc-algorithm=aes-128,3des dh-group=modp2048,modp1024 lifetime=1d dpd-interval=disable-dpd
My version of RouterOS is 6.42.1.
Any idea's will be appreciated.
Bas2033
Tue May 08, 2018 3:22 pm
Hi all,
I copied the code from the previous post into the Mikrotik. Unfortunately it didn't let me ping my subnet after the Mikrotik.
I use version 6.42.1 of the RouterOS software. Is there some one who can verify this finding on the current RouterOS version ?
Bas2033
Mon May 14, 2018 8:24 pm
Hi All,
Emils of Mikrotik helped me out. He said I correctly configured the router. So I rechecked my firewall settings on the windows box. Icmp ports were open. I could ping locally. I shutted the windows firewall complete down. Et voila it worked. I enabled the firewall again. I decided to use the command line to open for ICMP.
netsh advfirewall firewall add rule name="ICMP Allow incoming V4 echo request" protocol=icmpv4:8,any dir=in action=allow and netsh advfirewall firewall add rule name="ICMP Allow incoming V6 echo request" protocol=icmpv6:8,any dir=in action=allow. This worked with 6.42.1
Regards,
Bas
Users browsing this forum: Majestic-12 [Bot], vikinggeek and 45 guests
