wombat
More subnet in the LAN and L2TP
Mon Feb 08, 2016 7:05 pm
situation:
My LAN:
192.168.0.1/24
192.168.1.1/24 / Me
192.168.2.1/24 / NAS etc.
I have attached remote drives on the NAS, etc. On the 2.x, everything works, at the moment when you connect to the remote L2TP so it falls, because the subnet is routing over the VPN, not via the LAN, how to say MK to address-list not route through VPN?
Thx
Gabriel
ZeroByte
Re: More subnet in the LAN and L2TP
Mon Feb 08, 2016 7:12 pm
The easiest solution is to use another IP range for VPN endpoints (e.g. 192.168.3.x/24)
If you want to use IPs from 192.168.1.x as VPN endpoints, then you need to set the arp type to proxy-arp on the 192.168.1.x interface so that the VPN endpoints can appear to be directly connected to that LAN.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
wombat
Mon Feb 08, 2016 9:32 pm
vpn pool is 10.x.1.xx/24
ZeroByte
Mon Feb 08, 2016 9:45 pm
The clients need to add a route to your LAN whenever they're connected.
Look for split tunnel settings for VPN settings in the wiki
When given a spoon,
wombat
Tue Feb 09, 2016 11:43 am
1) without VPN
C:\Users\>tracert 192.168.2.2
Tracing route to NAS [192.168.2.2]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  router [192.168.1.1]
  2    <1 ms    <1 ms    <1 ms  NAS [192.168.2.2]
2) with VPN
Tracing route to 192.168.2.2 over a maximum of 30 hops
  1     5 ms     6 ms     8 ms  10.75.3.1
I know that can disable default gateway on client side.. But is possible on router side?
Gabriel
Users browsing this forum: jell2020 and 52 guests
