MUM Europe 2020
mozzi001
help me pls
Sat Feb 13, 2016 6:31 pm
dh
can someone guide mee
i have trouble with my setting
my networking configure:
ISP ---> Modem ADSL Router Wifi --> Mikrotik HapLite --> Switch / pc
i already setting like this
https://www.dropbox.com/s/42dab847ytyhg ... 2.jpg?dl=0
but now i can't connect to inet, can someone help me
thanks
pixelkop
Re: help me pls
Sat Feb 13, 2016 7:21 pm
export config and post
mozzi001
Re: help me pls
Sun Feb 14, 2016 7:11 am
i already make it...
but can i ask for some help pls
setting on modem adsl router
ip = 10.10.5.1
bridge on
dhcp disable
setting on mikrotik
eth1 = 10.10.5.3/24 (modem adsl)
eth2 = 192.168.3.1/24
wlan1 = 192.168.5.1/24
pppoe-client = dialup to modem adsl on eth1
gateway = pppoe-client
firewall nat = pppoe-client
dhcp = eth1
dhcp = wlan1
now my problem is...
i cant connect to modem adsl from mikrotik dhcp
pc --> switch/hub --> mikrotik --> modem adsl --> isp
and how i cant connect to inet from modem adsl
please help mee... sorry for my bad english
kiaunel
Re: help me pls
Sun Feb 14, 2016 3:24 pm
Was realy hard to understant what do you want to do.
Why do you have on ether1 ether4 and wlan1 an ip from the same subnet as your modem.
What is 5.0/24 netmask anyway.... modem subnet? if so 5.1 is not your modem ip? how do you connect to modem? dhcp? static ip?
I think you should start over and configure accees to adsl router, make sure your mikrotik can access internet. (try a ping to google.com from terminal)
Then for your network use a single ip with a single dhcp server on an ether port connected to your lan then bridge or set master interface on other ports.
if you realy need a setup like in your pictures try to set different ip subnets on every port. My bet is as i can see in your routes 10.10.5.0/24 present on ether1 wlan1 and 4 is your problem. But if you only need a simple setup make only one subnet for your lan.
mozzi001
Re: help me pls
Sun Feb 14, 2016 3:54 pm
sorry my bad
i already remake it
this time i already can connect to inet from my mikrotik
my question is how i can connect to inet from my modem adsl....??
help pls
thanks
kiaunel
Re: help me pls
Sun Feb 14, 2016 4:03 pm
So you can ping from microtik to internet right?
help pls
I don`t understant what means from "modem adsl"?
Don`t u try connect to internet from a computer connected to mikrotik lan?
ZeroByte
Re: help me pls
Sun Feb 14, 2016 5:03 pm
This is easily accomplished - just add another srcnat rule:
/ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade.
pppoe1 is a different interface than ether1 as far as IP is concerned. The modem doesn't have a gateway or static routes set, so when you try to access the modem from the LAN, the modem needs to see the source IP as one that it knows how to reach, which is why the new masquerade rule is necessary.
Also remove the 10.10.5.4/24 address from ether4
When given a spoon,
you should not cling to your fork.
The soup will get cold.
mozzi001
Re: help me pls
Sun Feb 14, 2016 6:34 pm
Thanks a lot to kiaunel and ZeroByte
u very2 kind
now one of my problem solve..... :D :D
thankss agaiinn
ZeroByte
Re: help me pls
Sun Feb 14, 2016 6:50 pm
u very2 kind
thankss agaiinn
I do exactly the same thing at my house so I can get to my cablemodem from my LAN, so I recognized immediately what you were trying to do. ;)
When given a spoon,
Users browsing this forum: No registered users and 30 guests
