geeko
How to detect when default gateway changes?
Wed Feb 17, 2016 12:04 am
Hi Everyone,
In a dual wan/failsafe environment, does anyone have an idea how I can detect the switch between WANs?
I'm asking because I need to perform some system cleaning (connection drops + email) when the system changes the default gateway
Many Thanks,
geeko
Re: How to detect when default gateway changes?
Thu Feb 18, 2016 3:38 pm
Hi Guys,
Thank you, I finally mange to figure this one out!
This is how I'm doing right now ( please feel free to step in! )
But I'm currently assigning a specific route for each WAN and track them using ICMP ping.
Best Regards,
geeko
scampbell
Trainer
Trainer
Thu Feb 18, 2016 9:09 pm
Hi Geeko,
If you are behind NAT'ed routers then that is the correct way to do it. It also enables a more complex check than just next-hop :-)
If you only need to check next-hop then there is also a setting in the default route called "check-gateway" which can use ping. No use if you are connected to another local router, but easy if your next hop is the ISP.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
boyko
Fri Feb 10, 2017 8:53 pm
Hi Guys,
Best Regards,
geeko
I don't see the script / solution - how did you solve this?
Users browsing this forum: No registered users and 10 guests
