MUM Europe 2020
nickel78
Cannot get port forwarding to work
Wed Feb 24, 2016 1:17 am
This is my first time using a Mikrotik device and cannot get it to do the port forwarding properly. I know that I just don't have the proper settings but after searching, I cannot find anything online that will work for me. I am trying to setup remote access to my Plex server. My previous router had simple port forwarding and was easily setup. This is the screen I get when trying to setup the forwarding. I am a beginner on these routers, so I know almost nothing.
pateutz
Re: Cannot get port forwarding to work
Wed Feb 24, 2016 3:15 am
So port forward,
Firewall -> NAT -> (+ Sign ) will open the new window and introduce the following :
Step1
General Tab you will fill in:
Chain ( dstnat ) - destination chain
Protocol ( tcp or upd ) depending of the service ..
DSt port ..
and in Interface ( external interface )
Step 2
Action
dst-nat
to address ( local addrres from you private interface )
to ports ( the port number of the app that running on internal server )
Finally select OK
Best Regards,
Daniel
nickel78
Wed Feb 24, 2016 3:30 am
Thank you for your quick reply. I tried what you suggested an I am still getting the same results. Is there anything else that could be missing?
kiaunel
Wed Feb 24, 2016 7:33 am
Post your firewall rules here.
In terminal :
ip firewall nat export
pateutz
Wed Feb 24, 2016 8:10 am
if the Plex server it's taking ip through DHCP server from Mikrotik ?
Please send us the NAT configuration that you done it, using the cli or pictures .
Best Regards,
Daniel
Revelation
Wed Feb 24, 2016 5:19 pm
You actually don't need to setup remote access on Plex, which is payware...
Follow pateutz's advice.
Your dst-nat should look something like:
chain=dst-nat action=dstnat in-interface="WAN" dst-port=23444 to-address=192.168.1.5 to-port=32400
fompt
Wed Feb 24, 2016 5:52 pm
Hi guys,
I've just tried to forward port on my hAP router, and couldn't get it to work, through testing found something that did worked, but is kinda weird:
change incoming interface from ether1-gateway to all ethernet. don't quite understand it but now it forwards correctly.
Any idea why?
Update: now I've changed it back to ether1-gateway and it is working. Really weird.
pateutz
Wed Feb 24, 2016 7:14 pm
Hi guys,
Any idea why?
So now it's ok !?
For more understanding please read the documentation from :
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT
or some presentations:
https://www.youtube.com/watch?v=LXoai9COaDM
https://www.youtube.com/watch?v=YEXGqt5QG08
Best Regards,
Daniel
fompt
Wed Feb 24, 2016 8:30 pm
Yep, now its working, I understand how firewall works (but thank you for links :) ), I don't get why "all ethernet" unblocked it somehow.
pateutz
Wed Feb 24, 2016 9:07 pm
Hi ,
i don't know relay. Sometime the OS it's not behave has should be.
Normally when i am seeing this kind of things i am running a reset configuration and starting over with the configuration.
But in this special setup that you have done it decently should work just with ether1-gateway not will all Ethernet.
Best Regards,
Daniel
kd6icz
Fri Jun 24, 2016 12:03 am
I am so confused.....
I am not a router expert by any means and I have been reading all these different threads on how to make my Plex server available to the outside of my network....  Everything I try doesn't work.
Isn't there a simple way to make this happen????
Please?
Users browsing this forum: Bing [Bot], Rughalt and 36 guests
