MUM Europe 2020
MaLegend101
Can't login with admin on SXT
Mon Feb 29, 2016 6:01 pm
Hi I'm tryiing to login on my SXT with Winbox. When I try to login with default admin username and password (admin, and nothing as password, right?) it says wrong username and password. I can login with "default" as username, but when I've logged in with that I haven't permission to do anyting. Please help, I'm a noob.
gabrielpike
Re: Can't login with admin on SXT
Mon Feb 29, 2016 6:48 pm
How are you resetting the device?
Gabriel Pike
MTCNA
jarda
Mon Feb 29, 2016 7:04 pm
Make the reset. Then log by default admin.
MaLegend101
Tue Mar 01, 2016 5:41 pm
How do I reset it?*
gabrielpike
Tue Mar 01, 2016 6:04 pm
I would suggest jumping the reset point on the board with a screwdriver (or something else that is metal). It should be a small hole with metal semicircles around it. Hold the screwdriver on it when you connect power.It should make some odd beeps as it boots. After that login with admin no password.
Gabriel Pike
MTCNA
MaLegend101
Tue Mar 01, 2016 6:44 pm
Jumping the reset point?
gabrielpike
Tue Mar 01, 2016 6:53 pm
This is the reset point.
Gabriel Pike
MTCNA
MaLegend101
Tue Mar 01, 2016 7:13 pm
Should it click or something when i but the skrewdriver in?
gabrielpike
Tue Mar 01, 2016 7:15 pm
no you are trying to jump the two sides when power is connected at start.
Gabriel Pike
MTCNA
MaLegend101
Tue Mar 01, 2016 7:17 pm
Connect the two metalic things together so they like get eachothers electricity?
gabrielpike
Tue Mar 01, 2016 7:20 pm
yes
Gabriel Pike
MTCNA
MaLegend101
Tue Mar 01, 2016 7:24 pm
Ok, I think I've done it now. Should it beep or something.
MaLegend101
Tue Mar 01, 2016 7:28 pm
I still cant login as admin. Can this be because my ISP sent me it?
gabrielpike
Tue Mar 01, 2016 8:16 pm
It is possible to pre-configure a device with netinstall which may be your only option.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Gabriel Pike
MTCNA
Users browsing this forum: No registered users and 41 guests
