reliance3g
Sxt lite 5 unable to update router os
Tue Mar 01, 2016 11:31 am
Sxt lite 5 router is ver 6.34.2 I had install i n my router is manually. But if I am going to upgrade latest is through the option in my router is .it was not detect automatically newest version.
Help need
normis
Re: Sxt lite 5 unable to update router os
Tue Mar 01, 2016 11:38 am
6.34.2 is already the latest version. there is no newer version
reliance3g
Tue Mar 01, 2016 12:38 pm
But before that latest version it was in 5.26.and I update it manually sir.it was not able to update automatic .err msg show could not solve DNS server
normis
Tue Mar 01, 2016 12:44 pm
It means you have no internet. Check settings in "IP address" and "IP DNS" menus.
Splash
Tue Mar 01, 2016 1:14 pm
The device itself is unable to resolve the Mikrotik update server hostname. If you don't obtain your IP address information automatically through DHCP, check that you have set up a DNS server within the Mikrotik RouterOS
shows that the router cannot resolve properly.
Example:
set servers=8.8.8.8,8.8.4.4
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
reliance3g
Tue Mar 01, 2016 3:15 pm
Now I want to clear every setting.want my device in default
Users browsing this forum: No registered users and 28 guests
