ik3umt
Routing performances comparison
Thu Mar 03, 2016 6:50 pm
Briefly, what is the routing performance capability of RB2011UiAS (with external switch) VS a CRS125-24G-1S-IN , both with a pair of ports connected to dsl router (10Mb/s dwn - 1Mb/sup dsl bandwidth) ??
Thank you
jarda
Thu Mar 03, 2016 7:00 pm
Compare the performance tables on product pages.
These speeds are routable with whatever mikrotik device even 10 years old like nothing.
ZeroByte
Re:
Thu Mar 03, 2016 10:01 pm
what is the routing performance capability of . . .
Adding to Jarda's advice, I'd recommend that you compare the routing-with-firewall-rules values for each platform - in particular, I'd say the middle-sized packet column is the most realistic for considering "real world" traffic, which is almost never all 1500-byte packets or tiny packets.
CRS is primarily intended to be a switch - so don't grab one thinking that you've got a beast of a router with a bazillion ports all over it - it's primary intent is to be used as a hardware-forwarded switch. When using the routing features, the CPU can take a big hit - notice the rapid drop off in performance on some CRS's performance tables.
However, as Jarda says, 10M is easily achievable with nearly any Mikrotik product.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
chechito
Re: Routing performances comparison
Thu Mar 03, 2016 11:25 pm
i think you are on the right point of a frequently asked question at the forum and their respective consequences of someone buying a device which in the field do not meet their expectations
i think mikrotik has to document and establish device performance beyond the actually published performance:
Bridging (fast path)
Bridging 25 bridge filter rules
Routing (fast path)
Routing 25 simple queues
Routing 25 ip filter rules
For example CISCO for ISR routers (direct competitor of some mikrotik products) has published documents about
iPsec Maximum performance per platform
Firewall performance throughput and concurrent sessions
QoS performance test using mixed size packets at 75% CPU usage
Nat performance test using mixed size packets at 75% CPU usage
Beyond That CISCO establish recommendations to position the device by:
IPSEC performance
Nat + QoS +ACL performance at 75% CPU usage with mixed size packets
All this information are consolidated in a more simple and GLobal Performance positioning:
WAN Circuit Speed with services enabled recommended for the device
ik3umt
Fri Mar 04, 2016 9:52 am
Thank you for answers
I've compared side by side those machines on routerboard.com
Cpu, cpu speed, ram size, storage size are the same
I have a little experience with 2011 and three to five dsl lines pcc/routing mark managed and a little firewall config
They all work flawlessly
So I suppose CRS machine would do the same
I've read about CRS problem in managing hi.speed dsl routers, but someway solved working around ethernet queues....
Any thougth ?
chechito
Fri Mar 04, 2016 12:35 pm
Any thougth ?
keep in mind some cpu resources go to managing the switch chip
jarda
Fri Mar 04, 2016 1:35 pm
But anyway crs125 will manage these speeds easily.
ik3umt
Fri Mar 04, 2016 4:50 pm
Nice to hear it from you... :D
Thank you
Users browsing this forum: No registered users and 29 guests
