MUM Europe 2020
cupid2404
Problem with Nat port for camera
Wed Mar 23, 2016 6:26 pm
I using RB1100AHx2 v6.27
I have registry no-ip host, and add this script + schedule for run script
# No-IP automatic Dynamic DNS update
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "USER"
:local noippass "PW"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "HOST"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "INTERFACE"
# No more changes need
#:global previousIP;
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
   :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address];
# Strip the net mask off the IP address
   :for i from=( [:len $currentIP] - 1) to=0 do={
       :if ( [:pick $currentIP $i] = "/") do={
           :set currentIP [:pick $currentIP 0 $i];
   :local previousIP [:resolve "$noiphost"];
   :log info "DNS IP: $previousIP, interface IP: $currentIP";
   :if ($currentIP != $previousIP) do={
      :log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed";
     # :set previousIP $currentIP;
      :local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP";
      :log info "No-IP: Sending update for $noiphost";
      /tool fetch url=($url . "&hostname=$noiphost") user=$noipuser password=$noippass mode=http dst-path=("no-ip_ddns_update-" . $host . ".txt")
      :log info "No-IP: Host $noiphost updated on No-IP with IP $currentIP";
   } else={
   :log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed";
} else={
   :log info "No-IP: $inetinterface is not currently running, so therefore will not update.";
Then, i NAT port 81 for camera device.
Now, when i type user.ddns.net:81, browser go to the page of camera device -> OK
But i just type user.ddns.net, browser go to page login router.
Why's that when I just NAT port 81 to ip camera?
kiaunel
Wed Mar 23, 2016 6:36 pm
How did u nat camera port?
Sent from my Lenovo K50a40 using Tapatalk
gabrielpike
Re: Problem with Nat port for camera
Wed Mar 23, 2016 7:04 pm
You could disable the http service on the router and enable https. If you are trying to NAT a web server port to port 81 in your dst-nat chain.
Gabriel Pike
MTCNA
Sob
Wed Mar 23, 2016 7:05 pm
Hostname points to address. It does not have to do anything with ports. So if you forward port 81 from you router's public address to internal camera, http://user.ddns.net:81 will connect to internal camera. If you don't forward port 80 anywhere, http://user.ddns.net will try to open webserver on your router. Simple as that.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
cupid2404
Wed Mar 23, 2016 7:29 pm
Thanks for replay.
Present, I don't forward port 80 anywhere. And i don't want http://user.ddns.net will open webserver on router. What should i do?
Sob
Wed Mar 23, 2016 9:40 pm
Rule like this will do the trick:
add action=reject chain=input dst-port=80 in-interface=<wan interface> \
    protocol=tcp reject-with=tcp-reset
It will still work from LAN, feel free to change it if you want. But remember that you won't be able to use WebFig if you do that (I don't know if you need it or not). In case you don't need WebFig, you might just disable it under /ip services and then you wouldn't need any extra blocking rule.
gabrielpike
Disable services you do not want to use:
Gabriel Pike
MTCNA
Users browsing this forum: rlopegar and 34 guests
