abdulrazaqa
CCR1036 not passing data through sfp
Thu Mar 24, 2016 8:20 am
Recently purchased 4 CCR1009-8G-1S-1S+, 3 CCR1036-12G-4S & 1 CCR1016-12S-1S+ and 12 pair of S-35LC20D....
Connected a CCR1016-12S-1S+ & CCR1036-12-4S using a 3m LC-LC fiber pictail using a pair of S-35LC20D, link is ok, but there is no layer 3 connectivity, i mean no data passing through it.. tried to contact support no response... it is frustrating, is there any one faced similar issue...
I tried all below steps
1. upgraded to latest firmware.
2. reset to factory default.
no luck yet
Following is the technical details
[admin@MikroTik] /interface ethernet> monitor sfp1
status: link-ok
auto-negotiation: disabled
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-module-present: yes
sfp-rx-lose: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: LC
sfp-link-length-9um: 20000m
sfp-vendor-name: Mikrotik
sfp-vendor-part-number: S-53LC20D
sfp-vendor-revision: 1.0
sfp-vendor-serial: SK151102B52517
sfp-manufacturing-date: 15-11-02
sfp-wavelength: 1550nm
sfp-temperature: 35C
sfp-supply-voltage: 3.243V
sfp-tx-bias-current: 3mA
sfp-tx-power: -5.495dBm
sfp-rx-power: -5.717dBm
[admin@MikroTik] /interface ethernet> /
[admin@MikroTik] > ip address print detail
0 address=10.10.11.117/30 network=10.10.11.116 interface=sfp1 actual-interface=sfp1
1 address=192.168.2.1/24 network=192.168.2.0 interface=ether1 actual-interface=ether1
[admin@CCR1016] /interface ethernet> monitor sfp5
status: link-ok
rate: 1Gbps
full-duplex: yes
tx-flow-control: no
rx-flow-control: no
sfp-rx-lose: no
sfp-tx-fault: no
sfp-vendor-part-number: S-35LC20D
sfp-vendor-serial: SK151102B33028
sfp-wavelength: 1310nm
sfp-temperature: 36C
sfp-supply-voltage: 3.256V
sfp-tx-bias-current: 12mA
sfp-tx-power: -4.143dBm
sfp-rx-power: -7.968dBm
[admin@CCR1016] /interface ethernet> /
[admin@CCR1016] > ip address print detail
0 address=10.10.11.118/30 network=10.10.11.116 interface=sfp5 actual-interface=sfp5
1 address=192.168.1.1/24 network=192.168.1.0 interface=sfp1 actual-interface=sfp1
Petzl
Re: CCR1036 not passing data through sfp
Thu Mar 24, 2016 11:47 pm
and with regular SFP modules ?
Can you test a longer cable or a attenuator ?
nickshore
Fri Mar 25, 2016 12:16 am
Try turning auto negotiation on
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
abdulrazaqa
Sat Apr 09, 2016 11:07 am
The issue resolved, problem is with a batch of sfp modules
Users browsing this forum: No registered users and 24 guests
