haccks
No "wireless" menu button in WinBox.
Tue Apr 05, 2016 4:16 pm
Why there is no "wireless" menu option in WinBox for RB 1100AHx2? How can I get that option?
normis
Re: No "wireless" menu button in WinBox.
this device has no wireless functionality
haccks
Tue Apr 05, 2016 4:20 pm
No. I am Talking about "wirless" options on the left hand side of the menu.
See in the pic: https://meylan31.files.wordpress.com/2014/12/27.png
In this video you can see the option for RB1100AHx2: https://www.youtube.com/watch?v=bAm9SXkkjK0
normis
Tue Apr 05, 2016 4:21 pm
To use CAPsMAN, you must install the wireless-cm2 package.
Here: http://download2.mikrotik.com/routeros/ ... 35rc46.zip
haccks
Tue Apr 05, 2016 4:24 pm
I know I have to install that package, but what about that "wireless" option button?
normis
Tue Apr 05, 2016 4:25 pm
Wireless option menu will only appear after installed the wireless-cm2 package
haccks
Tue Apr 05, 2016 4:50 pm
Well I installed the package and reboot the router but didn't get the option :(
ZeroByte
Tue Apr 05, 2016 4:53 pm
Are you using the latest version of Winbox?
When given a spoon,
you should not cling to your fork.
The soup will get cold.
haccks
Tue Apr 05, 2016 4:55 pm
Yes. I had to enable the package first and then reboot. Now It's worked :D
haccks
Tue Apr 05, 2016 6:17 pm
Thanks. Now it worked.
Users browsing this forum: cyb and 50 guests
