Can listen two ports ( TCP 443, 1194 ) on OpenVPN Server?
Refer to this topic, it seems WRT can support run two instance with tow Seperate Ports.
http://blog.omotech.com/?p=602
When ROS support UDP mode, how to port forward from TCP 443 to UDP 1194 ?I don't think it can run two instances, but with NAT port forwarding you should be able to get 1 instance to listen on two ports.
Use a dst-nat, when packets for port 443 come in via wan1, then action=dst-nat, to-port: 1194
