haccks
How to increase the address pool for a hotspot created on VLAN?
Thu Apr 14, 2016 5:18 pm
Currently I created a hotspot on VLAN10. The address pool for this is 192.168.10.2-192.168.10.254. How can I increase/add more address pool to this hotspot? For example if all IP addresses in the above range is occupied then new IP can be assigned from the pool 192.168.2.2-192.168.3.254 or 192.168.4.2-192.168.4.254 or 192.168.100.2-192.168.100.254 so that there can be more than 252 users on the network at a time.
Any help will be appreciated.
mjsabri
Trainer
Trainer
Re: How to increase the address pool for a hotspot created on VLAN?
Sun Jul 31, 2016 11:20 pm
Hello
you can use more ip address in ip pool but you should use bigger subnet
Mikrotik Certified Consultant
[ MTCNA , MTCRE , MTCWE , MTCTCE , MTCUME , MTCINE ]
haccks
Mon Sep 19, 2016 4:53 pm
Hello
Are you sure increasing subnet will work?
Users browsing this forum: erlinden and 122 guests
