korniza
[FOUND] CapsMAN snmp MAC Table
Thu Apr 21, 2016 7:41 pm
I'm looking for the oid that can return the MAC table of connected wireless clients from CapsMAN. First of all, it there available this option?
Please. help!
korniza
Re: CapsMAN snmp MAC Table
Thu Apr 21, 2016 8:29 pm
Found it!
In case someone required to get MAC table of connected wifi clients on remote CAPS, please use oid .1.3.6.1.4.1.14988.1.1.1.5.1.1
:D
I need it because I intergrate Mikrotik with home automation platform (Domoticz), so to detect mobile devices are present and trigger events (for example perform wake on lan).
soonwai
Re: [FOUND] CapsMAN snmp MAC Table
Thu Apr 21, 2016 9:03 pm
Thanks for that. It might be useful for me too in the near future.
chechito
Fri Apr 22, 2016 11:34 am
Found it!
:D
thx for the info
korniza
Fri Apr 22, 2016 6:44 pm
The rabbit hole of Mikrotik on oid is that the MAC-address oid appeared wrong on console:
/caps-man> registration-table print oid
 0 mac-address=.[u][b]1.3.6.1.4.1.14988.1.1.1.4.1.1[/b][/u].148.16.62.205.37.201.81 uptime=.1.3.6.1.4.1.14988.1.1.1.4.1.3.148.16.62.205.37.201.81 tx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.4.148.16.62.205.37.201.81
   rx-bytes=.1.3.6.1.4.1.14988.1.1.1.4.1.5.148.16.62.205.37.201.81 tx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.6.148.16.62.205.37.201.81 rx-packets=.1.3.6.1.4.1.14988.1.1.1.4.1.7.148.16.62.205.37.201.81
   tx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.8.148.16.62.205.37.201.81 rx-rate=.1.3.6.1.4.1.14988.1.1.1.4.1.9.148.16.62.205.37.201.81 tx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.10.148.16.62.205.37.201.81
   rx-signal=.1.3.6.1.4.1.14988.1.1.1.4.1.11.148.16.62.205.37.201.81
suppose it will fixed :D
Users browsing this forum: NtokzPro and 36 guests
