trangtrau
Can't connect between 2 subnet in 2 eth
Mon Apr 25, 2016 4:13 pm
Hi every one !
I have 2 ethernet with
- eth1 ip= 192.168.0.1/24
- eth2 ip =192.168.2.1/24
and cable form 2 ethenet put in to 2 othe switch. How to do for them see itself. Sorry for bad english
Mazutti
Re: Can't connect between 2 subnet in 2 eth
Mon Apr 25, 2016 8:50 pm
Hi every one !
If your router is gateway to both networks and firewall is not configured to drop connections between them, then it should work ok. Easy way to find out is disabling all Firewall/Filter rules, if it works, then some rule is blocking that traffic.
trangtrau
Tue Apr 26, 2016 11:24 am
i has disabled all ruler but nothing change.
blajah
Tue Apr 26, 2016 12:39 pm
Are ports eth1 and eth2 in same bridge ?
kiaunel
Tue Apr 26, 2016 3:43 pm
Post your config here. Use export commnad:
export hide-sensitive
blajah
Tue Apr 26, 2016 8:33 pm
One more thing, consider proxy-arp .
Users browsing this forum: AdamT77, dsfak, Javokhir, Kanzler, pmcsill and 113 guests
