MUM Europe 2020
serend
Can't open webpages
Wed Jun 01, 2016 1:02 am
I bought Mikrotik RB2011UiAs-2Hnd-IN today, i use quick set, home AP mode and PPPoE status is connected, I can open google, gmail, facebook websites, but I can't open most of other websites such as Wikipedia, www.sina.com.cn, www.creaders.net, etc., even I can ping these website, but can' t open, what's wrong with this router? :(
TyBermea
Re: Can't open webpages
Wed Jun 01, 2016 5:35 pm
I would have to look at your config, but the problem may not be the router. Some malware can cause problems like that.
Ty Bermea
MTCNA, MTCRE, MTCTCE, MTCUME, MTCWE
www.ispsupplies.com
pe1chl
Wed Jun 01, 2016 7:01 pm
I bought Mikrotik RB2011UiAs-2Hnd-IN today, i use quick set, home AP mode and PPPoE status is connected, I can open google, gmail, facebook websites, but I can't open most of other websites such as Wikipedia, http://www.sina.com.cn, http://www.creaders.net, etc., even I can ping these website, but can' t open, what's wrong with this router? :(
Try setting the MAX MTU and MAX MRU on your PPPoE interface to 1492 instead of 1500.
sjwrick
Fri Jun 03, 2016 4:43 pm
Sounds similar to problem I have.
Try setting a manual DNS server (8.8.8.8, 8.8.4.4) in the PC.
If that works try setting external DNS server in /ip dhcp-server network
Rick
ZeroByte
Fri Jun 03, 2016 4:50 pm
I think this is the most likely fix.
We had a similar issue with pppoe customers being uable to use certain sites, but everything else seemed to work flawlessly. The sites they complained about seemed to mostly be hosted on Akamai. We added the clamp-mss setting to our routers (cisco calls it adjust-mss) and then they were able to reach all websites.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
sjwrick
Thu Jun 16, 2016 6:43 am
So I am not using PPPOE.
I should set this on the Gateway router?  The client is a 3rd party router. (netgear, dlink, ) Set the MAX MTU/MRU to 1492 on the third party or on my central distribution router?
Rick
Users browsing this forum: Google [Bot] and 66 guests
