gableoley
two wan failover (webserver access) HELP PLEASE!!!
Wed Jun 08, 2016 10:20 pm
I have two wan balancer with failover 750UP, but I can't access my webserver from outside (internet)
Local : 192.168.1.0/24  ip 192.168.1.254 Web Server IP 192.168.1.6
wan1 192.168.2.0/24 ip 192.168.2.1
wan2 192.168.3.0/24 ip 192.168.3.1
Thanks in advance
This wan have dynamic IP
jarda
Re: two wan failover (webserver access) HELP PLEASE!!!
Thu Jun 09, 2016 6:47 am
Looks like you don't have public ip.
gableoley
Thu Jun 09, 2016 6:08 pm
Well the public ip its given by the ISP and it's dynamic, are you talking about that public ip?
jarda
Sat Jun 11, 2016 1:36 pm
So how would you access your router from outside? Hope the mangling for the two wans work good so you need only the dst nat rule to redirect the selected port to internal address. That's all.
gableoley
Sat Jun 11, 2016 10:36 pm
gableoley
Sat Jun 11, 2016 11:25 pm
This is what I have so far and it's working, I can reach my webserver from outside and local network putting the dynamic address provide by the isp.. thanks in advance.
# jan/02/1970 21:17:00 by RouterOS 6.7
# software id = CAGZ-SXJ9
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether5 ] name=ether5-slave-local
set [ find default-name=ether4 ] name=local
set [ find default-name=ether2 ] name=wan1
set [ find default-name=ether3 ] name=wan2
/interface pppoe-client
add add-default-route=yes disabled=no interface=wan1 name=pppoe-wan1 password=xx use-peer-dns=yes user=xx
add add-default-route=yes disabled=no interface=wan2 name=pppoe-wan2 password=xx service-name=wan2 use-peer-dns=yes user=xx
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=CEDASAMK ranges=192.168.1.200-192.168.1.253
add address-pool=CEDASAMK disabled=no interface=local name=dhcp1
add address=192.168.2.1/24 comment="default configuration" interface=wan1 network=192.168.2.0
add address=192.168.3.1/24 interface=wan2 network=192.168.3.0
add address=192.168.1.254/24 interface=local network=192.168.1.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=local
add address=192.168.1.0/24 comment="default configuration" dns-server=192.168.1.254 gateway=192.168.1.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
add address=192.168.1.254 name=router
/ip firewall address-list
add address=192.168.1.0/24 list=GW01_LAN
/ip firewall mangle
add chain=prerouting dst-address-list=GW01_LAN src-address-list=GW01_LAN
add action=mark-connection chain=forward connection-mark=no-mark in-interface=pppoe-wan1 new-connection-mark=ISP1_Conn passthrough=no
add action=mark-connection chain=forward connection-mark=no-mark in-interface=pppoe-wan2 new-connection-mark=ISP2_Conn passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-wan1 new-connection-mark=ISP1_Conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-wan2 new-connection-mark=ISP2_Conn
add action=jump chain=prerouting connection-mark=no-mark in-interface=local jump-target=policy_routing
add action=mark-routing chain=prerouting connection-mark=ISP1_Conn new-routing-mark=ISP1-Traffic src-address-list=GW01_LAN
add action=mark-routing chain=prerouting connection-mark=ISP2_Conn new-routing-mark=ISP2-Traffic src-address-list=GW01_LAN
add action=mark-routing chain=output connection-mark=ISP1_Conn new-routing-mark=ISP1-Traffic
add action=mark-routing chain=output connection-mark=ISP2_Conn new-routing-mark=ISP2-Traffic
add action=mark-connection chain=policy_routing dst-address-type=!local new-connection-mark=ISP1_Conn per-connection-classifier=both-addresses:4/0
add action=mark-connection chain=policy_routing dst-address-type=!local new-connection-mark=ISP2_Conn per-connection-classifier=both-addresses:4/1
add action=masquerade chain=srcnat out-interface=pppoe-wan1
add action=masquerade chain=srcnat out-interface=pppoe-wan2
add action=dst-nat chain=dstnat in-interface=local protocol=tcp src-port=80 to-addresses=192.168.1.6 to-ports=80
add action=masquerade chain=srcnat dst-address=192.168.1.6 dst-port=80 out-interface=local protocol=tcp src-address=192.168.1.0/24
add action=dst-nat chain=dstnat dst-address=dynamic ip dst-port=80 protocol=tcp to-addresses=192.168.1.6 to-ports=80
add action=masquerade chain=srcnat out-interface=wan1
add action=masquerade chain=srcnat out-interface=wan2
add check-gateway=arp distance=1 gateway=pppoe-wan1 routing-mark=ISP1-Traffic
add check-gateway=arp distance=1 gateway=pppoe-wan2 routing-mark=ISP2-Traffic
add check-gateway=arp distance=2 gateway=pppoe-wan1
add check-gateway=arp distance=3 gateway=pppoe-wan2
/ip service
set www port=8080
gableoley:
Users browsing this forum: johnalvi12, ruwerra and 30 guests
