ssb
2 wan static ip on RB1100AHx2
Thu Jun 16, 2016 12:49 am
Example:
WAN1 = 82.82.82.82/22 Gate = 82.82.82.1
WAN2 = 72.72.72.72/19 Gate = 72.72.72.1
LAN1 = 192.168.1.0/24
LAN2=172.16.0.1/24
 Id like to be able to srcnat
LAN1 to WAN1
LAN2 to WAN2
Thank you!
dgnevans
Re: 2 wan static ip on RB1100AHx2
Thu Jun 16, 2016 8:16 pm
Create srcnat for each connection with source ip as the ip of the lan you would to use for that wan. Put the out interface as the interface of the wan yo uwould like to use. Then setup router marks in the mangle and then your routes.
ssb
Thu Jun 16, 2016 10:41 pm
It can be an example to my settings
Thank you!
irghost
Fri Jun 17, 2016 7:50 am
/ip firewall mangle
add action=route chain=prerouting in-interface=LAN1 route-dst=82.82.82.1
try this i dont know if its gonna work or not  !!!
cause there is no wiki  for action=route
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
ssb
Fri Jun 17, 2016 8:31 am
/ip firewall mangle
Thank you. Does not work
Help me please !!!
irghost
Fri Jun 17, 2016 8:36 am
Use routing mar
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface=LAN1 new-routing-mark=to_Wan1
add action=mark-routing chain=prerouting in-interface=LAN2 new-routing-mark=to_Wan2
add distance=1 gateway=82.82.82.1 routing-mark=to_Wan1
add distance=1 gateway=72.72.72.1 routing-mark=to_Wan2
Users browsing this forum: No registered users and 39 guests
