MUM Europe 2020
MikroTikFan
Hoiw to limit access to webfig /graphs
Mon Jul 11, 2016 10:43 am
I need a help how to limit access to my graphs shared through webfig service
When I share access to my router before login I can see my graphics stats.
Is there any way to limit this information after login or switch off ?
amt
Long time Member
Long time Member
Re: Hoiw to limit access to webfig /graphs
Mon Jul 11, 2016 1:28 pm
change mikrotik web port and block it to outside or create firewall rule and give acsses only special addresses to accses....
efaden
Mon Jul 11, 2016 2:42 pm
No.  You can't do anything but restrict access to the interface or change the port.
ZeroByte
Mon Jul 11, 2016 7:50 pm
You can specify one (and apparently only one) IP range that's allowed access to the graphs on your interface rules / queue rules / resource rules
That's the only granularity available to you as far as "allow webfig / deny graphs" capability.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
MikroTikFan
Fri Jul 29, 2016 1:18 am
Thanks for all advice's.
I know that I can give different port to whole webfig and different for winbox app.
To be sure if I understand right webfig separation - is this possible to separate webfig access from webfig access/graphs on different ports ?
efaden
Fri Jul 29, 2016 3:30 am
No.
cdiedrich
Forum Veteran
Forum Veteran
Fri Jul 29, 2016 11:24 am
You can do it with the built-in web proxy.
Enable the web proxy, redirect inbound tcp/80 connections to it and set access restrictions (for denying/granting access to graphs, use the path /graphs/) in the proxy.
This can be done for literally any address ranges.
Just tested it here and it works. When accessing http://<router-address>/graphs you get a decent "Access Denied" message.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Users browsing this forum: BoroHap, fruitjuice, mbovenka, mojbuk, steffen2010 and 30 guests
