Stop17
Creating Hotspot
Tue Aug 16, 2016 9:33 pm
My idea is to create Hostspot for small municipality, 10.000 max client for start.
So now, range is somewhere, not more than 2-3 Km.
Can u guys suggest equipment that i need?
My budget is arround, 3000 $.
So, my idea is to launch this service only for mobile devices, coz at home they have internet connections, so i will assume they will use this hotspot only when they walking on the streets, to avoid 3G limited bandwidth.
Thanks in advance.
resetjet
Re: Creating Hotspot
Wed Aug 17, 2016 6:05 am
10,000 clients to start???? At 50 users per ap, that would be 200 ap's.....That would be a pretty large system for $3000.....Or is this someone from the forum playing a joke??????
TomosRider
Wed Aug 17, 2016 9:35 am
First, you should bring a Cisco router as a sacrifice to Netwerkus, the great and allmighty god that resides deep inside the caves of layer7. Once you have summoned him, loudly say:copper cables are crap!
and you should gain his trust. With his help, you should pull this off in no time.
Stop17
Wed Aug 17, 2016 11:49 am
This is Beginner area, so even joke is a question.
2nd, my idea is to provide free hotspot with limited daily bandwidth and limited hours.
But, i don't know where to start and what is recommend equipment...
Thanks.
resetjet
Wed Aug 17, 2016 4:25 pm
Ok, not a joke. The scale of what you are trying to do would require a very good professional at best. Not for a beginner by any stretch of the imagination. Also you are looking at $30,000+ not $3,000. You need some very expensive good gear,
Now that being said, you could install some gear for $3000 yourself, say 10 access points with a router to serve 500 clients, but even that would probably be a mess. You are either going to have to scale it down, or up the budget. Either way, what you are trying to do is hard for a pro, and is basically out of reach for a novice.
Users browsing this forum: aboiles, Bing [Bot] and 48 guests
