igpetkov
Ext and Internal access
Mon Sep 12, 2016 11:33 am
Hi, All!
I have a problem with opening pc from my local network through real ip, with NAT.
I use 3CX PBX which is installed on my server Windows Server 2008, and have FQDN from noip.com "myname.noip.com" and configured src-nat and dst-nat on RB 750. When I try to access my server from outside there is no problem, everything works fine, but if I try access server from Local Lan (connected to eth2) with outside FQDN or External IP I receive "can't reach this page" or simmilar from diffrent browsers.
I make static DNS record in my RB, which forward to internal server IP, but is there other decision? And is this problem from my configuration or from ISP?
I have RB 750 with WAN on eth1 and LAN on eth2.
NAT configuration:
chain=srcnat action=src-nat to-addresses=84.xxx.xxx.xxx src-address=192.168.1.0/24
out-interface=ether1 log=no log-prefix=""
chain=dstnat action=dst-nat to-addresses=192.168.1.250 protocol=tcp
dst-address=84.xxx.xxx.xxx
dst-port=80,443,3389,5000,5001,5060,5061,5090,5223,5228-5230,2195,2196 log=no
log-prefix=""
I try to change ARP option on eth2 to arp-proxy, but nothing change.
Can someone help me? Thank You
Sob
Re: Ext and Internal access
Mon Sep 12, 2016 2:21 pm
You want thing called hairpin NAT.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
igpetkov
Mon Sep 12, 2016 4:30 pm
Thank You, Sob!
It works great for me.
Users browsing this forum: No registered users and 56 guests
